Author Topic: UPdated wxGOES16&17(18)-HAniSLoops with New Image Series (& More!)  (Read 7293 times)
Offline weatherdoc
    • Willowsford Farm Weather
Re: UPdated wxGOES16&17-HAniSLoops with New Image Series (& More!)
« Reply #50 on: August 06, 2022, 08:47:52 AM »
Thanks for the updated files but the script isn't loading any images for me. Looks like the only changes to your script, inc-wxGOES18-HAniSLoops.php, are lines 541-549 and 556 that point to G18 instead of G17 on the NESDIS server. All I did was download your zip file, unzip it, and copied the files to my server. Maybe it's a cache issue on my PC? When you get a chance, could you open my webpage (https://novawx.dscloud.me/wxGOES18-HAniSLoops.php) and let me know if it works for you? Your GOES-17 script had been working fine. Obviously, the script is working on your website.
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #51 on: August 06, 2022, 12:00:19 PM »
My apologies!  The 'includes' script was calling for the GOES17 iframe instead of the GOES18 iframe.  I initially modified my GOES17 HAniS scripts to display GOES18, but I then realized that I needed 'GOES18' scripts instead.  So I modified and renamed them accordingly.  This meant that the egregious error went undetected because my modified GOES17 scripts hid it. #-o :oops:
A revised ZIP is available on my scripts page.  The same error was present in the 'Tabbed 16-18' script as well.
Thanks for your help! [tup]
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
« Reply #52 on: August 06, 2022, 10:50:05 PM »
I Wish theres also from West pacific. I already post my Topic regarding it and I hope sooner ken would also consider if ever ken asking for the embedded images, here is the link
for raw images.
https://www.data.jma.go.jp/mscweb/data/himawari/list_r2w.html
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
« Reply #53 on: August 10, 2022, 05:13:34 PM »
Hi Jerry,
It seems that my GOES17 - Western CONUS tabbed loop is not displaying the map for some reason. GOES 16 tab seems to be working okay.
Check out my site at:http://www.dwayneyamato.com/wx/wxGOES17-HAniSLoopsTabbed.php
Hope there is a solution or recommendation to resolve this issue.
Thanks for you support with your scripts.
Aloha,
--Stan Y.
  Maui, Hawaii
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
Offline gwwilk
« Reply #54 on: August 10, 2022, 05:16:57 PM »
There’s an updated GOES16-18-Tabbed zip on my scripts page that should solve your problem, Stan.
gwwilk@gmail.com
Offline Silversword
  • --Stan Y.
« Reply #55 on: August 10, 2022, 05:41:24 PM »
Hi Jerry,
Thanks for your reply and I have downloaded the GOES16-18-Tabbed zip and will have to upload it when time permits.
Do I upload all of those script. I did not see a script for GOES17.
Hope this will solve my issue.
Again, thanks for your support on your scripts and taking the time to address our issues.
Aloha,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline gwwilk
« Reply #56 on: August 10, 2022, 05:43:32 PM »
Upload them all after choosing your default location.
GOES17 has been deprecated.
« Last Edit: August 10, 2022, 05:45:06 PM by gwwilk »
gwwilk@gmail.com
Offline Silversword
  • --Stan Y.
« Reply #57 on: August 10, 2022, 06:01:24 PM »
Thanks Jerry, will do that and see what happens.
Aloha,
--Stan Y.
  Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline Silversword
  • --Stan Y.
« Reply #58 on: August 11, 2022, 05:05:41 PM »
Hi All,
Got my site up and running, yes, there is a "but", it seems that when I click on the Larger Image Loop, I get a page not found at this http://dwayneyamato.com/wxGOES18-HAniSLoops-SA.php this script is on my host from Jerry's zip file.
Everything else seems to be working great.
Thanks Jerry for you support again.
Aloha,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline gwwilk
« Reply #59 on: August 11, 2022, 05:09:32 PM »
Try uploading that file specifically after you have unzipped the scripts.  It should be there.
It's in your /wx/ directory.  You need to modify the script to accommodate the location of the files on your server.
« Last Edit: August 11, 2022, 05:15:09 PM by gwwilk »
gwwilk@gmail.com
Offline Silversword
  • --Stan Y.
Re: UPdated wxGOES16&17(18)-HAniSLoops with New Image Series (& More!)
« Reply #60 on: August 11, 2022, 05:47:32 PM »
Thanks Jerry. I think I found where I need to edit to point to the /wx directory located in the inc-wxGOES16-HAniSLoops.php and inc-wxGOES18-HAniSLoops.php script.
I just need to get that edited and upload to my host.
Thanks again for your support.
Aloha,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline Silversword
  • --Stan Y.
« Reply #61 on: August 11, 2022, 05:55:27 PM »
Just got it done and now working.
Thanks Jerry.
Aloha,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline gwwilk
« Reply #62 on: August 11, 2022, 05:56:28 PM »
 [tup]
gwwilk@gmail.com
    • PIMOHWEATHER
« Reply #63 on: August 15, 2022, 12:55:44 AM »
I hope theres also a modified version on this using SATCOMS from JMA, I dont have an Idea how to integrate those  :sad: :sad: :sad: :sad:
Offline gwwilk
« Reply #64 on: August 15, 2022, 06:27:16 AM »
I don't see any way that's possible either.  Sorry! :-(
gwwilk@gmail.com
Offline gwwilk
« Reply #65 on: November 20, 2022, 11:34:02 AM »
Well, NESDIS has decided that GOES17 is now GOES West, once again.
I've just re-uploaded all of the GOES17 scripts and added them back to the scripts menu.  I didn't 'touch' them with today's date, so you may need to hunt them down once you see that your current script(s) are displaying stale images, once again.  You can use the 'View' link to see which scripts are misbehaving.
gwwilk@gmail.com
Offline jfkuhn
« Reply #66 on: December 15, 2022, 12:02:57 PM »
Looks like Jerry's website is down.  Can someone post the scripts needed?
Offline gwwilk
« Reply #67 on: December 15, 2022, 12:06:36 PM »
Strange! My site isn't down for me. https://www.gwwilkins.org
« Last Edit: December 15, 2022, 12:08:35 PM by gwwilk »
gwwilk@gmail.com
Offline jfkuhn
« Reply #68 on: December 15, 2022, 12:18:12 PM »
Got on another computer and your website came up.  My firewall or something is blocking your site on my other computer.
Offline gwwilk
« Reply #69 on: December 15, 2022, 12:19:24 PM »
Good enough!
gwwilk@gmail.com
    • PIMOHWEATHER
« Reply #70 on: December 15, 2022, 09:21:12 PM »
JMA SATCOM since not possible to make similar in these scripts, I did some research at least and to create similar.
At least it did work some how. . I add border line for our area of responsibility line. . .  but still hope for modification to these soon
Offline drrehak
« Reply #71 on: December 02, 2023, 10:28:53 AM »
Just noticed that "Eastern Pacific" on wxGOES16-HAniSLoops.php wasn't displaying an image for me.  (Band sector eep)
Checked and not working on https://www.gwwilkins.org/wxGOES16-HAniSLoops.php
Wanted to pass the info along.
Dan Rehak | Pittsburgh PA
Davis Vantage Pro 2 Plus | Meteobridge Pro
Local Site | Raspberry Pi 4B
Offline gwwilk
« Reply #72 on: December 02, 2023, 11:14:46 AM »
Thanks for the helpful feedback. I'll look into it and if these images aren't being produced modify the script accordingly.
A quick look tells me that once again NESDIS has modified this part of their directory structure. It's going to be a while before I can investigate and then post a fix.  The GOES16 Eastern Pacific Animated GIF now also has incorrect directory information!
« Last Edit: December 02, 2023, 11:21:20 AM by gwwilk »
gwwilk@gmail.com
Offline gwwilk
« Reply #73 on: December 02, 2023, 09:48:05 PM »
I finally got a chance to dig into the code, and it turns out that NESDIS has simply changed the dimensions of the Equatorial Eastern Pacific images.  I have an updated HAniS-based script on my scripts page.
I'll see what I can do with the GIF animation when I get a chance.
Updated the GIF animation, and it is now on my scripts page, too.
« Last Edit: December 02, 2023, 10:35:40 PM by gwwilk »
gwwilk@gmail.com
Offline drrehak
« Reply #74 on: December 04, 2023, 09:11:22 AM »
Thanks for the quick response.
Installed and working.
