Author Topic: How to view my weather station in Windy website.  (Read 3181 times)
« on: April 29, 2020, 02:24:07 PM »
I have added windy to my meteobridge and i see the green checks but i do not know what i am missing or if i am doing this right. Please help
« Last Edit: April 29, 2020, 02:25:52 PM by Adrian23 »
Re: How to view my weather station in Windy website.
« Reply #1 on: April 29, 2020, 03:02:10 PM »
Looks like Windy is working. Seems like it is WeatherCloud that has an issue.
It would be helpful to post account/station IDs for us to double check and see working or not working status.
« Last Edit: April 29, 2020, 03:39:34 PM by galfert »
« Reply #2 on: April 29, 2020, 03:21:23 PM »
How come the station ID for Windy is blank?  On my Acuparse upload, I have to use my Windy station ID.
« Reply #3 on: April 29, 2020, 03:31:12 PM »
In the Meteobridge the shown Station ID: corresponds to the private station ID within your Windy account. The account you create in Windy is capable of being used for multiple locations/stations. The ID that you are referring to is the account ID not a station ID. To post to Windy you upload to an account ID and then if you don't also specify a station ID then your first station which is ID 0 is the default. The Meteobridge is providing the option of specifying the internal private station ID so that you can specify which of your stations you are uploading data to on your Windy account.
See below.
Red - Windy account ID - This is not a Station ID.
Blue - private station ID where 0 is the default first station created for the account
The Meteobridge only lets you specify the Windy account ID when you first configure the upload service. To erase it you have to either reset the Meteobridge, a bad option I think...or better option is to just download the configuration backup....edit the configuration backup with a text editor and remove Windy section....and then restore the fixed configuration file to the Meteobridge.
« Last Edit: April 29, 2020, 03:36:54 PM by galfert »
« Reply #4 on: April 29, 2020, 03:32:48 PM »
One more thing at the OP - when I fired up Windy upload, it took about 45 minutes to see my station on Windy.
« Reply #5 on: April 29, 2020, 03:34:04 PM »
See below.
The Meteobridge only lets you specify the Windy account ID when you first configure the upload service. To erase it you have to either reset the Meteobridge...bad...or just download the configuration backup....edit the configuration backup with a text editor....and then upload the fixed configuration file.
Ah...  thanks for the explanation.  I'm about to add a Windy station for my Davis (another location altogether different )  Good to know!
« Reply #6 on: April 29, 2020, 03:37:36 PM »
Hi guys,  all 3 checks but i just do not know were or how to view my station in windy.
« Last Edit: April 29, 2020, 03:40:40 PM by Adrian23 »
« Reply #7 on: April 29, 2020, 03:44:43 PM »
Go to https://stations.windy.com/stations to see your Windy account/station ID.
Then click on the station name as it will redirect you to: http: //stations.windy.com/stations/<your account id>
Then click on the icon on the following page for "see at Windy.com"
« Last Edit: April 29, 2020, 03:48:57 PM by galfert »
« Reply #8 on: April 29, 2020, 03:47:33 PM »
Then click on the station name as it will redirect you to: https://stations.windy.com/stations/<your account id>
it just spins forever...
« Reply #9 on: April 29, 2020, 03:50:05 PM »
As Bushman said...it takes a while. Check back later.
« Reply #10 on: April 29, 2020, 04:14:04 PM »
It’s been more then 3 hrs and it still just sits and spins.
« Reply #11 on: April 29, 2020, 05:06:16 PM »
« Reply #12 on: April 29, 2020, 07:23:07 PM »
Can’t be this long to start showing something not right.
Station f0706b12
« Reply #13 on: April 29, 2020, 09:33:54 PM »
https://www.windy.com/station/pws-f0706b12?26.175,-80.262,8  So there must be something wrong with your upload.
Offline josecmorales
« Reply #14 on: April 30, 2020, 10:33:44 AM »
Station f0706b12
I see it working! take it easy! sometimes the weather networks have issues.
Vantage Pro2 + UV, Airlink, Purpleair, Meteobridge.
Twitter: ClimaGuayana
Blitzortung station: 2934
Weatherlink: ClimaGuayana
