Author Topic: Inside Temp  (Read 839 times)
Inside Temp
« on: April 25, 2020, 07:49:49 AM »
Any services out there like WU that offer inside temperature in graph form?
Currently trying WL.com but they charge for the service.
Weathercloud is an option but you can't link directly to it. They do have another option but it only updates once an hour.
Any place else ya'll know about?
Offline ixlr8
Re: Inside Temp
« Reply #1 on: April 25, 2020, 09:11:51 AM »
I am using AmbientWeather and they graph inside temps as often as you upload, mine is set for 5 min. BUT you need a license to upload to their site. My license came with the AmbientBridge (Meteobridge) that I am using for uploading. They just reduced the price of their license, if I a remember correctly it is still stupid expensive in my book.
Offline BeaverMeadow
Re: Inside Temp
« Reply #2 on: April 25, 2020, 09:26:04 AM »
Acurite with MyAcurite
ex:
Re: Inside Temp
« Reply #3 on: April 25, 2020, 09:27:58 AM »
Ambientweather.net has indoor temperature and humidity a d dewpoint. For a Davis station all you need is a Meteobridge with the Ambientweather.net $100 license (used to be $160), or get a WeatherBridge from Ambient which is their version of the Meteobridge with the required license already baked in.
WeatherBridge (Meteobridge) $145
https://www.ambientweather.com/amweatherbridge.html
« Last Edit: April 25, 2020, 09:32:27 AM by galfert »
Re: Inside Temp
« Reply #4 on: April 25, 2020, 09:35:17 AM »
Should have mentioned I am using the wifi logger. There are several options on there but none to sites you guys mentioned. May have to go with WL.com for $47 a year.
Re: Inside Temp
« Reply #5 on: April 25, 2020, 09:49:13 AM »
You could also get a separate unit. Does it need to be tied into your Davis?
If you get an Ecowitt GW1000 for $36 then it will upload to Ecowitt.net. You'd get graphs and data charts at no charge. You could even add extra WH31 $13 sensors up to 8 of them and monitor different indoor rooms.
GW1000
https://www.amazon.com/ECOWITT-Gateway-Temperature-Humidity-Pressure/dp/B07JLRFG24/
WH31
https://www.amazon.com/ECOWITT-Multi-Channel-Temperature-Humidity-Sensor/dp/B07JLRJRLM/
« Last Edit: April 25, 2020, 09:52:00 AM by galfert »
