Author Topic: Capturing sensor data.  (Read 2418 times)
Offline AndyB
    • RAH66 simulator
« on: April 20, 2020, 10:01:19 AM »
Hi Guys 'n Gals,
A while ago my wife purchased an Oregon Scientific weather station that uses wireless (433Mhz) sensors. The base station works fine but there is no way to log the data.
I found a receiver circuit based on an Arduino that grabbed and decoded the data. That worked well and I was able to stuff the data in to a database. Problem was the USB kept dropping out and I'd lose days of data each time as I had to do a hard reset to get it to work again (seems to be a common problem with USB).
Does anyone here know, or have made a similar system using a raspberry Pi ?
I'm thinking of the Pi as it's network based and I could grab the data that way.
Any advice/help would be appreciated.
Cheers,
Andy
PS I'm a retired Electronics/ICT technician so am handy with a soldering iron and some coding ;)
Modify message
Home Simulator Cockpit at www.simpit.me.uk
Current Weather Station is Oregon Scientific WMR86NX
Re: Capturing sensor data.
« Reply #1 on: April 20, 2020, 10:06:07 AM »
RTL_433 on Software Defined Radio running on a Pi will  do this.  There are a lot of tutorials around.  Weewx seems to be the most popular DB to store the data and there is a full setup of it from Matthew Wall IIRC.
Offline Storm017
« Reply #2 on: April 20, 2020, 04:07:16 PM »
« Last Edit: April 20, 2020, 09:02:16 PM by Storm017 »
Offline AndyB
    • RAH66 simulator
« Reply #3 on: April 21, 2020, 04:58:35 AM »
Thanks guys. I'll have a read through the links.
Cheers,
Andy
Offline hmderek
    • Meteodrenthe
« Reply #4 on: April 26, 2020, 08:17:35 AM »
I've used an RFXtrx433XL USB 433.92MHz Transceiver, hooked up to a Raspberry Pi, to collect the data.
This post I wrote - mostly for my own benefit - has some relevant links: https://dbxit.com/enabling-rfxcom-protocols-using-rfxcmd-on-linux
There are other options available, like Rflink.
Another option is using Home Assistant, which also gives you the option to read data from a 433mhz receiver. It has a built in web socket server which you can subscribe to. It can send event updates every time a sensor update is received.
https://www.home-assistant.io/integrations/rfxtrx/
https://www.home-assistant.io/integrations/rflink/
https://www.home-assistant.io/integrations/websocket_api/
Domoticz is also an option and easy to set up. But I believe it has less options when you want to forward your data somewhere else. Also, in my case it tended to freeze up, making it less useful.
« Last Edit: April 26, 2020, 08:19:27 AM by hmderek »
Davis VP2
Davis WeatherLink
Sensirion SHT35
PT100
NTC Thermistors
DS18B20
Apogee Instruments TS-100
Barani Meteoshield Pro
Davis 7714
MetSpec RAD14
Davis AirLink
Wemos D1 Mini micro controllers
https://blog.meteodrenthe.nl
https://meteodrenthe.nl
https://twitter.com/meteodrenthe
