Author Topic: Help with creating html for website  (Read 966 times)
Offline Gruve5
    • Gruver Weather Service
« on: June 03, 2019, 11:15:52 PM »
Because of the Wunderground Rapid Fire going away, I am looking for other ways to display current temp, Humidity, Dew Point, Rainfall, Pressure and Wind.  I know a little bit about html, however, I can't quite figure out how to get the info from Virtual Weather Service to my own website just like Rapid Fire use to do. Can anyone help?
Offline 92merc
  • BismarckWeather.net
Re: Help with creating html for website
« Reply #1 on: June 04, 2019, 05:15:26 PM »
You really should look at going towards the Saratoga Scripts that are already out there.  There is a config to use VWS.  You'll have 10 second updates similar to WU's rapid fire.  The work has already been done.  You just need to switch your site out to using it.
https://saratoga-weather.org/wxtemplates/install.php
