Author Topic: Adjusting Clock Time On Vantage Pro2 Console  (Read 3070 times)
Offline WindsorDave
« on: December 12, 2018, 01:22:05 PM »
After operating for 3 years the console clock in the Vantage Pro2 has lost about 3 minutes.
The user manual shows how to initially set the time when installing the console.  I could not make sense of the directions as they related to clock time adjustments later.  I did not want to "re-install" the console since that might result in losing the historical data.
So how do I correct the time in the console without losing historical data?
TIA
Newbie with a Davis Vantage Pro 2.
Offline Jasiu
    • LexMAWeather
Re: Adjusting Clock Time On Vantage Pro2 Console
« Reply #1 on: December 12, 2018, 02:24:22 PM »
I've never had to do this but I believe you enter setup mode, press DONE a few times until you get to the screen with date and time, adjust as necessary, and then press and hold DONE to exit setup mode.
Just don't do a Clear All and I believe you are OK.
https://lexmaweather.info
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #2 on: December 12, 2018, 02:30:27 PM »
Start on page 11 here.
I recently had a similar problem and adjusted the time using these instructions.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline Old Tele man
  • Singing in the rain...
« Reply #3 on: December 12, 2018, 03:10:48 PM »
You can go "through" the WL 6.0.4 software with WL-IP logger as well:
1) Select SETUP
2) Select Set TIME & DATA
3) Enter new/corrected TIME
4) Select SET to end and exit.
« Last Edit: December 12, 2018, 04:07:15 PM by Old Tele man »
Offline Mattk
« Reply #4 on: December 12, 2018, 04:05:17 PM »
That if the console has a logger, but not mentioned, probably not?
Offline WindsorDave
« Reply #5 on: December 13, 2018, 04:15:27 PM »
Thanks for the tips, guys.  Will try and report back.
Offline WindsorDave
« Reply #6 on: December 13, 2018, 05:09:51 PM »
Going back and re-reading the instructions provided a better understanding.  Was able to adjust the time without clearing the historical data.
Thanks again to all who responded.
Offline WiFiLogger
« Reply #7 on: December 15, 2018, 07:01:01 PM »
All clock devices on the world uses quartz crystal 32.768 KHz.
Each one is different. Sometimes when you loose 1 min per 24h is quite normal.
If you you are loosing 1 min per year it's very precise.
Offline dcsmith
« Reply #8 on: October 01, 2022, 03:11:29 PM »
Pull a battery out for a few seconds.  You'll have to go thru the initial setups again including date & time.  However you won't lose your historical data.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #9 on: October 01, 2022, 03:47:39 PM »
I'm struggling to figure why you resurrect an old thread with such poor advice.
Offline dcsmith
« Reply #10 on: October 01, 2022, 03:48:48 PM »
Because I was in the same situation.
What would you do to reset the TOD?
Offline Mattk
« Reply #11 on: October 01, 2022, 04:40:36 PM »
Simply go into the Console setup mode and set the time, absolutely no need to be pulling power or batteries to re-initiate a new config/setup
