Author Topic: The wxnwswinter.php  (Read 9605 times)
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
Re: The wxnwswinter.php
« Reply #75 on: December 20, 2021, 07:37:44 PM »
Looks like the Gaylord Office, APX, is back up and running.
Hope it holds.
CW3699
« Reply #76 on: December 21, 2021, 08:22:01 AM »
Hope it holds.
I emailed the Gaylord NWS office about it a couple of days ago.
Offline Otis
  • (aka Paul)
« Reply #77 on: December 21, 2021, 09:29:45 AM »
Great Greg, thanks.
CW3699
Offline Jasiu
    • LexMAWeather
« Reply #78 on: December 23, 2021, 08:10:32 AM »
The graphics on the images without "_BOX" are now out of date. The projections have come down since those were originally issued.   :sad:
Sigh. They are back to using the file names w/o "_BOX". Going to see if I can figure out an easy way to determine which is in use (possible to scrape the "winter" page they display, although I'd like to avoid that).
https://lexmaweather.info
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #79 on: December 23, 2021, 08:28:54 AM »
Meanwhile I'll revise the script.  Thanks, Jasiu!
Comparing the file creation dates, if accessible, on the two image schemes might provide a switch point?  I would flounder around a lot before I successfully scripted that.
Revised script now available on my scripts page.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline Jasiu
    • LexMAWeather
« Reply #80 on: December 23, 2021, 01:38:11 PM »
The "last-modified" HTTP header field appears to be accurate for the image times. I have some test code in my sandbox now and will let it simmer for a while.
Offline weatherdoc
    • Willowsford Farm Weather
« Reply #81 on: January 02, 2022, 09:34:34 AM »
Nice script! It's working fine for me after installing it this morning. Looking at the first possible snow of the season in Northern Virginia tomorrow.
https://novawx.dscloud.me/~thunder/wxnwswinter.php
Offline gwwilk
« Reply #82 on: January 08, 2022, 07:44:46 AM »
Glasgow is no longer an exception.
An updated script can be found here.
gwwilk@gmail.com
Offline gwwilk
« Reply #83 on: January 09, 2022, 07:09:44 AM »
Thanks to a persistent user a dead link to the NWS has been eliminated from the script.
Thanks to this user the link has been updated to display the selected WFO’s home page.  I feel that this is a better landing spot for the curious viewer than the WPC’s home page.  This required slight revision of the primary and the includes scripts, so be sure to upload all after you’ve customized the primary and if desired the StandAlone scripts to your preferred WFO.
The primary script now hunts for the StandAlone script and displays the link only if it’s found and the active script isn’t the StandAlone one.
As usual the revised scripts are available here.
gwwilk@gmail.com
Offline 92merc
  • BismarckWeather.net
« Reply #84 on: February 07, 2022, 03:20:12 PM »
I just noticed my graphic is no longer updating.  Last update shows Feb 2.  Their site shows last Feb 4.
https://www.weather.gov/images/bis/ProbMessaging/StormTotalSnow_NorthDakota.png
Offline gwwilk
« Reply #85 on: February 07, 2022, 03:39:00 PM »
Somebody's asleep at the switch there.  You might prod them with a gently worded email.  I don't see any reason to update to a less outdated, but still outdated, graphic.
gwwilk@gmail.com
Offline gwwilk
« Reply #86 on: February 09, 2022, 05:24:52 AM »
It looks like they're back on the job at Bismarck after a long winter's nap. [tup]
gwwilk@gmail.com
Offline 92merc
« Reply #87 on: February 09, 2022, 11:31:41 AM »
Yeah, I'm guessing someone went on vacation.  To someplace warmer...  :-)
Offline gwwilk
« Reply #88 on: June 30, 2022, 07:07:25 AM »
On a lark I loaded this script this morning.  Much to my surprise my default WFO's predicted snow and ice images were up-to-date!  I didn't check any others because I wanted to leave well enough alone...
gwwilk@gmail.com
Offline tmabell
    • Mishawaka Weather
« Reply #89 on: June 30, 2022, 07:36:08 AM »
Mine are there but outdated because my default office does not update them out of season.
