Author Topic: .BIN Files  (Read 4895 times)
Offline nolversteeg
    • meteoeersel
.BIN Files
« on: February 13, 2009, 07:42:39 AM »
Hello Friends,
I'm new on this Topic. Mij Name is Nol and living in The south of Holland playing for 2 jears with VWS and a WMR 928N, so far no problems , but! now I try to redirect the .BIN data from the root of my HDD where is is stored by VWS ,  to c:\VWS\Data\Bin\ . "Not" with copy and paste but with settings in the VWS programm I looked evrywhere but did not find a solution to change this.
Plaese thanks in advance,
Nol Versteeg
Meteoeersel
Offline jay_hoehn
    • Jay's Woodcrafts
Re: .BIN Files
« Reply #1 on: February 13, 2009, 10:09:03 AM »
Nol,
You may need to do a complete reinstall.  All my .bin files are in VWS/setup.  This is the way VWS originally set them up.  Did you do a different install in the beginning?
Jay
Davis Vantage Pro2 Plus
VVP
Weather Display
Offline nolversteeg
    • meteoeersel
Re: .BIN Files
« Reply #2 on: February 13, 2009, 10:18:58 AM »
Hallo Jay,
Thanks for your reaction, as far as a now did i a normal install, all the bin files are on it's place only the 3 .bin files for exemple 2009.bin ,2009_13_2.bin and 2009_2.bin are in the root.
Nol
Offline Axelvold
Re: .BIN Files
« Reply #3 on: February 13, 2009, 11:08:21 AM »
Hallo Jay,
Nol
Hi Nol
those files should be in the folder named data and not in the root.
i think you could do a new instalation and then copy all the files to there right folders.
Lars Magnusson
Axelvold / Sweden
55° 57' 41" N / 13° 6' 1" E
Offline nolversteeg
    • meteoeersel
Re: .BIN Files
« Reply #4 on: February 13, 2009, 11:26:36 AM »
OK Lars,
I just did a update to te beta version, The files i pointed at are not the only, there are 3 .bin files every day from about 4K. There is somewhere in the programm VWS an instruction that  places the files over there.
Nol
MeteoEersel
Offline Axelvold
Re: .BIN Files
« Reply #5 on: February 13, 2009, 12:08:57 PM »
OK Lars,
Nol
MeteoEersel
i was wrong, the bin files should be in the setup folder
Lars Magnusson
Axelvold / Sweden
Offline nolversteeg
    • meteoeersel
Re: .BIN Files
« Reply #6 on: February 13, 2009, 12:34:32 PM »
Hi Lars,
Thats correct, the are all there, exept the files i meantioned in the conversation before, I dont know where the files stand for but don't want  them in the root.
Nol
Offline nolversteeg
    • meteoeersel
Re: .BIN Files
« Reply #7 on: February 13, 2009, 01:57:50 PM »
Hello meteofriends,
I did a clean install on another notebook(server) , and also there are the same bin files in the root.
Offline Anthony
  • Moderator
    • Anthony's Weather
Re: .BIN Files
« Reply #8 on: February 13, 2009, 06:59:10 PM »
I have no bin files what so ever in my root diretory. Just a few htx files and some jpeg files. Running 13.01p9.
Anthony
WB8YUE
Offline nolversteeg
    • meteoeersel
Re: .BIN Files
« Reply #9 on: February 14, 2009, 04:31:44 AM »
Hello friends,
The bin files are not installed within VWS, but, are written when the WMR 928N is connected,
Offline Anthony
  • Moderator
    • Anthony's Weather
Re: .BIN Files
« Reply #10 on: February 14, 2009, 08:17:46 AM »
If these files are being written when the station is connected and are being written to that specific directory. They are being written there for a reason.
Anthony
WB8YUE
Offline nolversteeg
    • meteoeersel
Re: .BIN Files
« Reply #11 on: February 14, 2009, 08:41:02 AM »
Thank's Anthony,
Can you tell me the reasen why the are written in the Root directory, and what te purpose of these files is , because it's a great mess at the end of the year  356 day, 12 month and 1 year Bin  File's in the root directory.
Nol
Meteo Eersel
Offline Anthony
  • Moderator
    • Anthony's Weather
Re: .BIN Files
« Reply #12 on: February 14, 2009, 08:48:31 AM »
Sorry Nol, But I don't have an answer for you on that.
Anthony
WB8YUE
Offline Scalphunter
Re: .BIN Files
« Reply #13 on: February 17, 2009, 04:55:40 PM »
I run a wmr100 here and it shows a  forecast52.bin in the root  of VWS  which is the forecast data coming from the console. So with what I see and what you write that data is from your console  for VWS to use if you were using it to forecast weather. Check and I think you will see those foile date time stamped as of today
KL7IFP
