Author Topic: FireFox Fonts?  (Read 4274 times)
Offline WeatherBeacon
  • Chief
    • http://www.wxbeacon.com
FireFox Fonts?
« on: December 23, 2008, 05:53:23 PM »
Hi friends.
i know many of you prefer using FireFox over other browsers. I just downloaded and installed it. However, the fonts appear less crisp than in IE. They appear slightly fainter and almost "dot matrix"-like. Is that normal? Is there a setting I can change to get crisper fonts?
Thanks!
Kevin...
Mae govannen!
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
Re: FireFox Fonts?
« Reply #1 on: December 23, 2008, 06:36:42 PM »
Do you have clear type on or off in windows appearance settings?
  • Chief
Re: FireFox Fonts?
« Reply #2 on: December 23, 2008, 08:56:20 PM »
Sam:
I'm not familiar with that. How do I check it?
Kevin...
Mae govannen!
Offline mmorris
  • Hope your day is full of sunshine
    • Weather and Racin
Re: FireFox Fonts?
« Reply #3 on: December 23, 2008, 08:59:00 PM »
Look in the control panel.
Sam:
Kevin...
>>Miles<<  By from Portage Lakes, OH.
Been using VWS since 1996 Ver# 14.01P43
Wireless Vantage Pro2Plus Serial Data Logger, Anemo Tran Kit
Win XP, Firefox, WXSIM, Cumulus, NexStorm, Yawcam, VVP, BadBlue Web server, Quake Catcher Net
Follow me on twitter
Vietnam era Veteran USAF bb loader
Quadruple Bypass survivor
Offline W Thomas
  • Welcome to my area!
    • Smyth-Grayson Weather
Re: FireFox Fonts?
« Reply #4 on: December 23, 2008, 09:04:00 PM »
Sam:
Kevin...
I have noticed that as well.. I also have not found much of a remedy to the situation. I have changed font types and made a little difference but
not enough to be concerned about. I usually have mine set to let the website use a different font than what I have set as default.
IE does have the better appearance it seems but it's usually a trade off for security versus appearance.
http://support.mozilla.com/en-US/kb/Firefox+Support+Home+Page    Has some pretty good information most of the time...
Wayne
www.smythweather.net
CW8217
     Best Regards
     Wayne
CWOP CW8217
KVAWHITE22 Wunderground   Davis VUE &  Davis Vantage Pro 2  /   Dedicated Server
  • Chief
Re: FireFox Fonts?
« Reply #5 on: December 24, 2008, 04:19:40 PM »
Sam:
Kevin...
Miles:
I did check Control Panel, but I don't understand the path. Can you be more specific?
Thanks!
Kevin...
EDIT:  Just for clarification, it doesn't seem Windows-related as the fonts in IE look crisp, clear, and well defined. It's the fonts in FF that seem pixelated. The graphics are also fine in FF.
« Last Edit: December 24, 2008, 04:28:56 PM by WeatherBeacon »
Mae govannen!
Offline ironton
    • Irontonwebcams /Weather
Re: FireFox Fonts?
« Reply #6 on: December 24, 2008, 04:37:56 PM »
Sorry about jumping into the middle of this discussion - but since I use Firefox/Mozilla almost exclusively I wondered if I was missing out on something  ;) - so I did a bit of searching.  What I found said this:
You can turn on font smoothing for Firefox, but there is a catch—you have to turn it on for all of Windows at the same time. To turn it on, go to the “Display Properties” dialog box (either through the control panel or by right-clicking on a blank area of the desktop and choosing “Properties”), click the “Appearance” tab, then click the “Effects” button. Under “Use the following method to smooth edges of screen fonts” choose “ClearType.” This will add the same font smoothing effect in Internet Explorer 7 to everything in Windows, including Firefox.
Perhaps in the future Firefox will add a setting to use ClearType that overrides the global Windows setting (this is what Internet Explorer 7 does now). Until then it’s all or nothing.
from this blog:
http://chris.calabrese.org/?p=27
I am not sure if that will help in your case but figured I should share it just in case.
Merry Christmas to all from the 'Tip of the Mitt.'
-ed
Davis VP2 using VWS
http://www.charlevoixweather.com using Cumulus
  • Chief
Re: FireFox Fonts?
« Reply #7 on: December 24, 2008, 04:44:46 PM »
Wow! That did it! Thanks, Ed. I don't think I would have found that. I'm surprised it wasn't easier to find that fix on FF's troubleshooting or Q&A sections.
There you go, Wayne. Give it a try.
Thanks all!
Regards,
Kevin...
Mae govannen!
