Author Topic: PHP Space Weather Script  (Read 14179 times)
Offline smokie
    • Newquay Cornwall. UK
Re: PHP Space Weather Script
« Reply #25 on: April 10, 2017, 02:09:50 AM »
It appears you are still getting the error, just tried your wxspace page.
I should of mentioned the cache file needed to be deleted so as to force refresh data, there has to be something different with your set up as it shouldnt take more than a couple of seconds.
These are the only settings needed to be changed to match your set up, assuming jpgraphs installed
path to cache file
$cacheName = "/home/XXXXX/public_html/xxxxx/sunspots/".date("Y")."/sunspotscache30d.txt";
Create dir for year
if (!is_dir('/home/XXXXX/public_html/xxxx/sunspots/'.date("Y"))) {
    mkdir('/home/XXXXX/public_html/xxxx/sunspots/'.date("Y"));
The script goes in wxgraphs
Hope this helps,
phil
« Last Edit: April 10, 2017, 02:11:39 AM by smokie »
Newquay, Cornwall.UK  > WS2300 Operational since May 2007. New home from 6/4/08 www.newquayweather.com
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #26 on: April 10, 2017, 08:07:48 AM »
I've narrowed the problem to an inability of 'sunspots30day.php' to reliably fetch and save the 'sunspotscache30d.txt' data, for reasons unknown to me.  Many times it ends up with an empty file which trashes the space script completely.  I've disabled the sunspot graph in my 'wxspacewx.php' until this problem can be sorted out.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline smokie
« Reply #27 on: April 10, 2017, 09:50:24 AM »
Just a thought do you have slow broadband ?
You could try increasing the time out from 30 to a higher figure in this line, as this was an issue when I
first wrote the script for some users.
$ctx = stream_context_create(array('http' => array('timeout' => 30)));
With todays speeds now it could be reduced
phil
« Last Edit: April 10, 2017, 10:00:00 AM by smokie »
Offline gwwilk
« Reply #28 on: April 10, 2017, 10:36:51 AM »
phil
I have a 300+ Mb fiber optic connection, so there should be no issue with broadband.  I already tried increasing the timeout to 120 earlier today, but that didn't help either.
I'm on a GoDaddy shared Linux web server, and constantly upload my weather data and files in addition to running chron jobs using cURL quite often in order to sidestep their meager curl restrictions.  I suspect that an overloaded web server is the problem.
gwwilk@gmail.com
Offline smokie
« Reply #29 on: April 10, 2017, 03:17:03 PM »
I to have fibre to the house, its excellent
Does the script produce any errors apart from the header one ?
I've attached a cached file see if it produces a graph
Offline gwwilk
« Reply #30 on: April 10, 2017, 06:08:30 PM »
The script occasionally produces a graph when the 'sunspots30day.php' script manages to scrounge the data.  When it doesn't I've modified (last night) the cache refresh logic to
if ((file_exists($cacheName) and filesize($cacheName)>30) and filemtime($cacheName) + $refetchSeconds > time()) { because the dead filesize is 30.  This still doesn't reliably produce a data file.
I just tried running 'sunspots30day.php' alone and after deleting the bad 'sunspotscache30d.txt' it ran once.  Then it refused to run again.  I'll get back at it probably tomorrow.  I played around with the directory structure a little, but didn't get anywhere yet.
gwwilk@gmail.com
Offline smokie
« Reply #31 on: April 11, 2017, 01:18:51 AM »
I'm puzzled by this, what php version do you have I'm on 5.6, I wonder if any other users are having the same issue
Offline gwwilk
« Reply #32 on: April 11, 2017, 08:09:13 AM »
PHP 5.4
gwwilk@gmail.com
Offline gwwilk
« Reply #33 on: April 11, 2017, 06:50:26 PM »
After trying multiple options including
$ctx = stream_context_create(array('ftp' => array('overwrite' => true)));rather than
I adopted a defensive strategy for this recalcitrant download.  I defined the following
'$testCache = (my path)/sunspots/sunspots30day-test.txt' and then I added, in context,
  $text=file_get_contents($ftp_server, 0, $ctx);
  if (strlen($text)>30) { // If we have data
file_put_contents($cacheName, ""); // only then zero file
  } else { // Otherwise!
file_put_contents($testCache, (date("M j, y: g ia",time()).' - strlen($text): '.strlen($text)."\n"), FILE_APPEND);
  exit; // Don't trash the last good data!
  while ($line < $lineend) {
    $split = preg_split("/[\n]/", $text, -1, 0 );
in order to avoid trashing a good data file.
I reactivated my cURL job to run 'sunspots30day.php' at 9 minutes after every hour in order to  give me some idea of how often the script is falling over by looking at my '$testCache'.  After 24 hours I might have a better idea of how often it fails.  I've also added the sunspots graph back to my 'wxspacewx.php' script.
This might not totally cure my problem, but it will hopefully at least minimize the symptoms.
gwwilk@gmail.com
Offline smokie
« Reply #34 on: April 12, 2017, 02:24:33 AM »
I just tried your page, no main content was displayed
try entering the data url and image url in your browser
ftp://ftp.swpc.noaa.gov/pub/latest/DSD.txt
and
https://sohowww.nascom.nasa.gov/data/realtime/hmi_igr/512/latest.jpg
takes about a second here to display both image and data
Update
Just tried your page again and its working
in the script found error
$bgimageurl="https://sohowww.nascom.nasa.gov//data/realtime/hmi_igr/512/latest.jpg";
change to
$bgimageurl="https://sohowww.nascom.nasa.gov/data/realtime/hmi_igr/512/latest.jpg";
extra /  got in (gov//data) take one out
« Last Edit: April 12, 2017, 03:16:47 AM by smokie »
Offline gwwilk
« Reply #35 on: April 12, 2017, 08:16:06 AM »
Good eye, Phil!  Unfortunately correcting the munged image url didn't improve the retrieval of the data file.  I see, and have seen, that the data file is retrieved quickly when its url is entered alone on the address bar, but when the url is called by 'sunspots30day.php' it somehow frequently falls over.
The php 'exit()' command I placed in 'sunspots30day.php' wasn't performing as I intended by returning to the calling script but as it should according to the documentation by exiting all scripts.  Replacing it with 'return;' should do the trick (Dreamweaver correctly forbids potentially using any values with 'return()' in this instance but rather insists it only be 'return' when not used in a function).  I'm leaving my cURL of 'sunspots30day.php' in place for now but running it every half hour now, so at most the graph should be just an hour or two old.
gwwilk@gmail.com
Offline smokie
« Reply #36 on: April 12, 2017, 10:04:30 AM »
Its a puzzle, i wonder if its anything to do with php version ?
The data file needs only to be updated once a day, I update mine around 04:30 GMT, this was done by trial and error
The DSD url will list when the file was updated, todays was
:Product: Daily Solar Data            DSD.txt
:Issued: 0825 UT 12 Apr 2017
The refresh part was for the background image
Offline gwwilk
« Reply #37 on: April 12, 2017, 11:06:58 AM »
Good to know!  I'll work with that in mind.
gwwilk@gmail.com
Offline gwwilk
« Reply #38 on: April 12, 2017, 07:47:33 PM »
I've backed off my cURL of 'sunspots30day.php' to run every hour and have 'sunspots30day.php' checking for an expired data file only every 24 hours while still checking for a background image no older than 1 hour.  As insurance I still have 'wxspacewx.php' 'include_once('sunspots30day.php')', but it should the script shouldn't hang and should always load promptly unless there has been a real problem with the data file.
Still a mystery why my GoDaddy server has such a problem. :?: :shock: :?:  It almost makes me want to host my website myself.  Almost.
gwwilk@gmail.com
Offline smokie
« Reply #39 on: April 13, 2017, 05:08:34 AM »
Jerry, been having a think, I've tried using ftp_get, works for me on the rough script to download dsd.txt
<?php
// define some variables
$local_file = 'DSD.txt';
$server_file = '/pub/latest/DSD.txt';
$ftp_server = 'ftp.swpc.noaa.gov';
$ftp_user_name = "anonymous";
$ftp_user_pass = "";
// set up basic connection
$conn_id = ftp_connect($ftp_server);
// login with username and password
$login_result = ftp_login($conn_id, $ftp_user_name, $ftp_user_pass);
// try to download $server_file and save to $local_file
if (ftp_get($conn_id, $local_file, $server_file, FTP_ASCII)) {
    echo "Successfully written to $local_file\n";
} else {
    echo "There was a problem\n";
// close the connection
ftp_close($conn_id);
« Last Edit: April 13, 2017, 05:19:36 AM by smokie »
Offline gwwilk
« Reply #40 on: April 13, 2017, 08:00:41 PM »
My server still stalled on the 'ftp_get', so I'm sticking with what I've got for now.  If it falls over after 24 hours, the cURL running every hour will keep trying to update the  stale data until it's successful, then it will stop updating for another 24 hours.  Meanwhile my graph is still present on the server and the users see no delay displaying wxspacewx.php.  This graph is also used in my 'wxastro5.php' script, which had been running the '30G' script but it was cheating by running on your site without the delay.  The graph also displays when I use 'http://www.newquayweather.com/wxgraphs/sunspots30day.php', and that would probably have been the simplest, albeit somewhat underhanded, solution.  These astro-wx scripts aren't much used by my viewers, but I like them.
gwwilk@gmail.com
Offline smokie
« Reply #41 on: April 14, 2017, 02:13:40 AM »
I'm at a loss now,  I'm on bluehost have been for years, do any of your other scripts use ftp_get or file_get_contents ?
Offline gwwilk
« Reply #42 on: April 14, 2017, 08:25:58 AM »
Here's one, but I didn't write it.  I only use it, and it at times is recalcitrant but likewise eventually comes through, although sometimes only after repeated <CTRL><F5>'s in Chrome or FF when the cache is defeated with '?cache=r'.
gwwilk@gmail.com
Offline smokie
« Reply #43 on: April 16, 2017, 09:34:09 AM »
I'm at a loss now, this has to be a GoDaddy issue, perhaps another GoDaddy user can shed some light on this, there seems to be a lot of pages if you search google
Try this, its using cURL, it seems to work even with an ftp url for me
<?php
$curl = curl_init();
curl_setopt ($curl, CURLOPT_URL, "ftp://ftp.swpc.noaa.gov/pub/latest/DSD.txt");
curl_setopt($curl, CURLOPT_FOLLOWLOCATION, true);
    $text = curl_exec ($curl);
    echo $text;
    curl_close ($curl);
« Last Edit: April 16, 2017, 09:43:58 AM by smokie »
Offline W3DRM
    • Emmett Weather
« Reply #44 on: April 16, 2017, 11:51:01 PM »
Jerry,
Almost a week ago you answered a question regarding what verion of PHP you were running. Your answer was 5.4. Is there anyone else successfully running the code on that version of PHP? I never saw any response to your reply and we have seen some code not run correctly on certain versions of PHP. Is there anyway you can upgrade to a later version of PHP?
--- RIPE Atlas Probe - 32849
Offline gwwilk
« Reply #45 on: April 17, 2017, 08:19:10 AM »
Jerry,
Nope.  I'm apparently stuck at 5.4.19 with as far as I can see no ability to upgrade.
gwwilk@gmail.com
Offline gwwilk
« Reply #46 on: April 17, 2017, 08:28:13 AM »
<?php
    echo $text;
    curl_close ($curl);
The data file was retrieved by this simple script, but only after a 20-30 second delay.  I'm wondering if there isn't some sort of GoDaddy-wide malicious script filter the results have to pass through before they're given the 'OK'.
gwwilk@gmail.com
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #47 on: April 17, 2017, 01:43:12 PM »
Quote from: gwwilk
best to contact your provider. 5.4 was discontinued in 2015 and is now out of support.  minimum they should be using is 5.6
http://php.net/supported-versions.php
Regards Simon
Offline smokie
« Reply #48 on: April 17, 2017, 03:15:51 PM »
<?php
    echo $text;
    curl_close ($curl);
20 secs is way to long as well, as Toxic says perhaps you can upgrade php
Offline W3DRM
    • Emmett Weather
« Reply #49 on: April 19, 2017, 03:40:50 PM »
Jerry,
I just finished a chat session with GoDaddy support. Here is what they say they provide in the way of PHP support:
  • Native/Basic PHP coverage is with 5.4
  • You can upgrade FREE to either 5.5.38 or 5.6.30
All you have to do is contact their support group to get the upgrade (according the chat I just had).
