Author Topic: CWOP posting issue  (Read 16222 times)
Offline frank_blac
CWOP posting issue
« on: March 27, 2012, 03:09:47 PM »
Hi Ken,
 I have an issue with uploading our data to cwop that I was wondering if you could help with?
our string is;
DW9787>APRS,TCPXX*:@212002z5088.76N/00119.53W_122/  6g  9t -2r...p...P...h91b...CitectSCADA
our programmer wrote a script that he is confident is functioning properly, are there issues with the data we are trying to send? I've reviewed the faq and all I can see wrong are the spaces.
we are not using Ham, we are collecting the data from our SCADA system.
is there a better area i should post this question?
thanks for your time,
Ian
Re: CWOP posting issue
« Reply #1 on: March 27, 2012, 03:44:40 PM »
Hi Ian,
I don't have any experience with scripting to produce a CWOP data submission .. sorry.
The format for the text string should likely not include blanks, but be zero-filled for all numeric variables.
Compare my posting via Weather-Display to yours:
CW1792>APRS,TCPXX*,qAX,CWOP-2:@261942z3716.48N/12201.38W_164/003g008t056r000p004P000b10190h56L392.WD 31
I suggest the developer use ftp://ftp.tapr.org/aprssig/aprsspec/spec/aprs101/APRS101.pdf as the guide for formatting the APRS weather report string.
Best regards,
Ken
« Last Edit: March 27, 2012, 03:56:07 PM by saratogaWX »
Offline W3DRM
    • Emmett Weather
« Reply #2 on: March 27, 2012, 03:53:33 PM »
...snip...
The link above should be "ftp.tapr.org/aprssig/aprsspec/spec/aprs101/APRS101.pdf". The forum software seems to want to put a http:// in front of the link.
--- RIPE Atlas Probe - 32849
« Reply #3 on: March 27, 2012, 03:57:10 PM »
Pesky, BBcode stuff... yes, I changed it to NOT be a hotlink.  SMF seems to preface with http:// everything that looks like an URL.  Thanks Don...
Best regards,
Ken
Offline frank_blac
« Reply #4 on: March 27, 2012, 03:57:33 PM »
thanks for the quick response folks,
we will try that script.
cheers,
Ian
« Reply #5 on: March 27, 2012, 04:01:21 PM »
Ummm.. that wasn't a script per se... it was the specification on how to format a APRS weather data submission.
At http://www.wxqa.com/cwop_info.htm your developer could look at a perl, python or Java program to do the weather data submissions.
Best regards,
Ken
Offline frank_blac
« Reply #6 on: March 27, 2012, 04:03:41 PM »
10-4,
thanks
Offline frank_blac
« Reply #7 on: April 25, 2012, 04:10:44 PM »
Hi Folks,
just wanted to thank you and let you know that we are live!
http://www.findu.com/cgi-bin/wxpage.cgi?call=DW9787&last=48
cheers,
Ian
