Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
Looking good! With the louvers and the opening at the top it may work fine without a fan. Should be sort of a chimney effect with heat exiting the top and pulling air into the bottom. Probably best to keep your sensors as low toward the bottom as possible for accuracy.
That ought to move some air around in there.
