Weather Station Hardware => Ambient Weather and Ecowitt and other Fine Offset clones => Topic started by: bam on January 13, 2022, 11:25:36 PM
Will the Ambient Weather WH32M https://ambientweather.com/amwh32m.html (https://ambientweather.com/amwh32m.html) work with the Ambient Weather ObserverIP Module properly?
I would like to an Ambient Weather WS-2801A with sensor and use the sensors also with the Ambient Weather ObserverIP Module https://ambientweather.com/amobserverip.html (https://ambientweather.com/amobserverip.html).
Working with the Ecowitt GW1000 would be an added bonus.
I call Ambient Weather and their support persons said is should work.
I'm not sure that is correct. The 32M only has three addresses (and I don't know if they are equivalent to the WH31 range). Someone else ever try this? Well, some docs say it's three channel, other docs say it's eight.
