Author Topic: Fall 2016  (Read 26168 times)
Re: Fall 2016
« Reply #250 on: November 28, 2016, 06:06:27 PM »
GFS forecast for snow next 2 days. I'm looking at an 1-2" is all here.
Offline Scalphunter
Re: Fall 2016
« Reply #251 on: November 28, 2016, 06:22:07 PM »
Well at 15 below now and  hour of daylight yet sunset around 3 these days. Be under 5 hours of daylight starting in December.  Once sun drops behind the horizon  temps will really start to drop.  Plugged the old ford in to  keep engine block warm so make easier on bearing  when starting.
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #252 on: November 28, 2016, 06:37:48 PM »
It is too early for snow! Call somebody to complain. I am still trying to fix a drainage issue from last year. A couple underground gutter extension drains froze last year and when melting on the roof occurred in March, the frozen gutter extensions wouldn't let the water come down the gutter downspouts, rather it flowed into my house!
Offline Scalphunter
Re: Fall 2016
« Reply #253 on: November 28, 2016, 07:55:28 PM »
Just hit our coldest temp so far this winter. at sunset it was -20 and  we are dropping in temp at 4 deg./hour according to WD software.
 If just  going  on the Dew point and  drop rate  I can hit down around 29 below tonight.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Fall 2016
« Reply #254 on: November 28, 2016, 08:00:49 PM »
-2 here ;)
Re: Fall 2016
« Reply #255 on: November 28, 2016, 08:10:39 PM »
29 below? :shock:
Offline Scalphunter
Re: Fall 2016
« Reply #256 on: November 28, 2016, 08:13:19 PM »
29 below zero  the same temperature your freezer is at.
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #257 on: November 28, 2016, 08:23:59 PM »
-2 here ;)
Celsius or Fahrenheit? I believe your country uses Celsius, if so not that cold!
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #258 on: November 28, 2016, 08:48:34 PM »
Yes, Celsius :)
Btw.... all countries use C - except yours :D (and a very few small ones) :D
Re: Fall 2016
« Reply #259 on: November 28, 2016, 08:57:57 PM »
Yes, Celsius :)
True, but our scale has better cardinal precision. ;)
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #260 on: November 28, 2016, 09:38:02 PM »
Our makes more sense :grin:
Freezing point is  0, boiling is 100
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #261 on: November 28, 2016, 09:51:58 PM »
On paper that makes sense, however, that is only at sea level. Much of the State of Colorado, for example, is a mile high (in feet) and boiling point at that elevation is 200F or less.
Re: Fall 2016
« Reply #262 on: November 28, 2016, 09:52:47 PM »
Everything metric makes more sense.
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #263 on: November 28, 2016, 09:55:09 PM »
Disagree. It is what a person gets used to, and I hate the metric way of measuring. That said, if I was raised on metric, I would probably like it and hate the US way!
« Last Edit: November 28, 2016, 10:06:59 PM by WheatonRon »
Re: Fall 2016
« Reply #264 on: November 28, 2016, 10:07:46 PM »
Well, Ron, just cause it's what you're "used to" doesn't mean it necessarily makes more overall sense. No?
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #265 on: November 28, 2016, 10:29:13 PM »
The U S will never change, rightly or wrongly, so I will accept the US way, and conclude it makes more sense, at least for Americans!
Re: Fall 2016
« Reply #266 on: November 28, 2016, 10:59:58 PM »
I was born and raised until age 10 in metric (remember well the little cups we had in school, from very small to 1 litre, each 10 times larger than the other, and how easy it was to remember).  Then to the imperial system in Canada and learning an inch being the King's thumb and a yard his reaching-out arm...  #-o until metrication in the 1970s when gas went from about $1 to 25c :-s  and we could drive 100 per/h 8)
It took me about 20 years to quit converting in my mind from metric to imperial, and now totally quite comfortable with metric, except understanding L/100 vs mpg ;)
So actually you can get used to it, and like it \:D/
Offline WheatonRon
    • WUnderground
Re: Fall 2016
« Reply #267 on: November 28, 2016, 11:34:42 PM »
Ain't going to happen in the US in my life time (I am retired). Probably unfortunate, but there is no impetus in the US to change. Until an impetus results, no change will result.
Offline Scalphunter
Re: Fall 2016
« Reply #268 on: November 29, 2016, 05:27:11 AM »
we would got metric here  but the cost of retooling everything would be to great and set back  the industry.  lot of ships I sail on had Metric and British Whitworth  then throw in SAE and you have an mess.
Offline Scalphunter
Re: Fall 2016
« Reply #269 on: November 29, 2016, 05:28:58 AM »
As of 0100 we hit 30 Below here.  getting close to that spot where C and F is the same.  Maybe this week if no down slope winds  come into play.
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #270 on: November 29, 2016, 06:38:33 AM »
I totally understand that you are used to it.
But I have to disagree with you and say that metric indeed does make more sense. Simply because it is based on multiples. Not just the 0 and 100 on the Celsius scale, but also other measurements.
Just a few examples:
100cm = 1m
1m = 1000km
1000g = 1kg
1000kg = 1 ton
vs
1ft = 12in
1mi = 5280 in
16 ounces = 1 pound
etc etc....
Re: Fall 2016
« Reply #271 on: November 29, 2016, 08:35:01 AM »
As far as F vs C , I'll take F. The US resisted the larger size of each degree Celsius so to eliminate fractions and increase the granularity of the scale thought the F scale was better. I agree with this theory and glad at least for temperature we stayed on the Fahrenheit scale.
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #272 on: November 29, 2016, 10:31:27 AM »
Yes, I sort of agree with that. You could also say that in F, the 100 I think corresponds to human body temperature and the point you made also makes sense.
however with the other measurements (length, weight etc.) metric just is much easier to calculate with, there is no doubt about that. If for example I asked you what is 5.4 pounds in ounces or I asked you what is 350g in kg, surely one would be much easier for you to calculate in your head.
Re: Fall 2016
« Reply #273 on: November 29, 2016, 11:04:54 AM »
Believe that was the thinking 100F body temperature actually 98.6F and the other end 0F was the coldest the Germany Physicist Fahrenheit experienced in his town.
The metric system otherwise is better IMO.
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #274 on: November 29, 2016, 11:11:26 AM »
Yes I know it is not exact, but thats how he defined it... I guess he probably had a fever when he was doing it :D
