Here is latest qc report that was in my mail box this morning. It appears this one is a summary for the week. Im guessing I received it because again my wind speed is off but it appears that my wind direction is off as well.
Im still confused as to what the numbers in parenthesis represent.
I checked the anemometer arm and it is pointed at the magnetic north. To get to true north I need to move it almost 7 degrees to the right or east (if I have my bearings correct for Michigan declination). I will fix that this week. Mike
DATE UTC * ALT * POT TEMP * DEW PNT * DD * FF
* (MB) * (DEG F) * (DEG F) * (DEG) * (KNT)
17-JAN-2010 Week * 0.3(0.44) *0.42(1.13) *-0.1(0.82) * 2.1(38.
*3.74(2.09)
Note that times are in UTC. The values displayed are 'Observed (error)'
The error value is 'analysis - observed'. I.e. if your observed value is higher
than the computed value, then the error will be negative. You have to pick out
the reading that is in error. The row with the time of 'Smry' is a daily summary
and the data is 'mean(standard deviation)' for each observation during that
day.
The 'Week' row is the summary for the preceding 7 days.
Graphs:
http://weather.gladstonefamily.net/qchart/D4210?date=20100118
