My GW1000s (3), WH2650s (2) have been working for months now without any issue.
Only my new GW1100 had an issue the other day (of course just when I was away for a couple of days
it stopped sending data to ecowitt.net, strangely enough it continued posting data via the customized server function.
And I couldn't connect anymore via the WebUI.
When I was back home, the WSView app also failed to connect.
The red LED was on constantly, no occasional blinking as my other GW1000s do.
My router would still show its IP as connected - when I disconnected the GW1100 power supply, it disappeared from the router (to be expected).
So I did a reset - no change in symptoms. I tried a factory reset, but nothing would happen - neither with pressing the middle button nor by using a staple end on the backside.
Pressing the reset button > 5 seconds would results in 3 blinks of the red LED, then all went out and it restarted - still the red LED not blinking.
I simply didn't get a factory reset working which would result in a fast blinking LED, no matter how long I held the reset button, entered a staple pin into the reset hole, powered it off for a longer time.
However, after a few restarts, the router recognized the "old" IP again, the WSView app connected and the WebUI could be reached again - and it (the GW1100) sent data again.
All still the same (old) IP address (MAC bound).
Still the red LED remains only on constant light and a factory reset is impossible.
I'm wondering if I should complain with Ecowitt as it now continues doing its job ...
