Hi Wim, I am using LTS-version 2020-12
There are times when the gust speed sticks, for lack of a better term.
At present there is a calm, no wind, yet the template is showing a gust of 4mph
Other variations of the template are showing 0 gusts and i have not seen this issue
previously. Your latest version
hereOther versions with no sticking gusts are
https://www.brecklandweather.com/PWS34-X5wxsimhttps://www.brecklandweather.com/pwsWD/http://www.brecklandweather.com/pwsWD12/I have recently got WLL and there are times when i see the gust speed stick in WD
but that generally sorts itself out, I'm still waiting for Brian to answer that one but
i do not think it is related to the above issue because WD is showing 0 wind whilst
your latest version is still showing 4mph and interestingly enough, that sticking gust
is not reflected in the graph on the template, although you can see when it sticks in WD.
PS, i have made a few tiny alterations to the script, 1 is the clock in dark mode, 1 is
update times and the other is the inside temp is no longer rounded off, the sticking
issue was there before i changed the clock or indoor temp. This version is only for
personal use at home for now, i will have an unmodified version for public use later on.
PPS, gust is
dropped to 2 now but still stuck at 2mph now stuck at 10mph,
one other is the METAR EGYM i changed to EGUL but EGYM is still in the status and
as stalled, not sure how to get rid of it i tried deleting the EGYM txt file but that didn't
do it from the status.arr
