I came across this thread and was wondering how the FARS mod worked out? Did you stay with the daytime FARS or do a phase II upgrade to 24 x 7 FARS?
Hi Frank, the bluetooth sensor fit nicely. Since I didn't have a passive shield to start with, I was going to order the 7710 passive shield but the individual components I needed to complete the stack cost significantly less. Because of the various versions, it took me a while to determine exactly what I needed. Here's a summary of my Scaled Instruments order:
- FARS conversion kit (7747)
- 2 open plates (7342.236)
- 1 closed plate with threaded studs for the bottom (7342.098)
- 1 closed plate with non-threaded studs for the 2nd bottom (7342.099)
- mounting bracket (7353.080)
The 7747 kit came with 1 open ring so my FARS stack has 3 open rings and two closed bottom plates. The 2nd closed bottom plate protects the sensor from ground reflected radiation. I only needed to find locally (3) long 8-32 stainless screws & washers to attach assembly to mounting bracket. They go through the mounting bracket and FARS stack into the threaded studs on the bottom plate. For the time being, the solar panel that came with the 7747 kit (intended to replace SIM cover) is held in place on top of the bracket with duct tape
The sensor was previously mounted inside the north facing front porch, but daily highs were always significantly biased on the high side compared to the nearby ASOS station KFHU, especially when the air is calm (KFHU is only 7 miles away, but 380' higher in elevation). As expected, the FARS temperature readings are more in line with KFHU considering the difference in elevation, so I'm guessing the porch must heat up above ambient. I haven't decided yet if I'll add batteries and charging kit for 24-hr ops.
