Author Topic: AW Meteobridge primary and station 1  (Read 211 times)
Offline Platokidd
  • top side land of Lincoln
« on: August 04, 2021, 11:09:43 PM »
I added a 2nd station to my AW meteobridge. Thus now i have a primary and station 1. However what is the purpose of station 1, I dont see any changes other than station 1 . see pic. [ You are not allowed to view attachments ]
« Last Edit: August 04, 2021, 11:41:53 PM by Platokidd »
CWOP:FW5295 | :FW6969
WU:KILPLATO3 | :KILROCK100| :KILCRYST84
Ambient
2- WS-2000 2-WS-2902A ARRAYS 1-CONSOLE 2-WH40-RAIN 1-WH31L 1-METEOBRIDGE 2-PM2.5
3-WH-31E 1-SRX100LX 1-WH31SM
ECOWITT
2-HP2551C 1-WS68 1-WH51 6-WH31 2-wh32
3-GW1000 1-GW1100 1-WH45 1-WH51 1-WH32EP
1-Stratus Rain
Re: AW Meteobridge primary and station 1
« Reply #1 on: August 05, 2021, 07:17:20 AM »
The purpose is to get different data from a 2nd station console (up to 5 I believe). If both consoles are receiving the same data and they are thr same model then there isn't much point other than redundancy. Typically the purpose is for those that have for example an Ecowitt console and a Davis and they want to use the Meteobridge for both console data.
Another purpose might be that you want to have more than 8 WH31 sensors. Then the first GW1000 gets the first 8 and then the additional are received by the 2nd. Then the Meteobridge combines all the data.
« Last Edit: August 05, 2021, 07:21:35 AM by galfert »
Offline Gyvate
« Reply #2 on: August 05, 2021, 08:38:20 AM »
If you have e.g. two GW1000 and have an outdoor WH65 array but also a WS68 and a WH40, you can configure your GW1000 such that e.g. GW1000 (1) receives the rain data from the WH65 and GW1000 (2) from the WH40,
same with wind: WH65 or WS68, or with more than 8 WH31 (see before @galfert) or more than 8 WH51, or 2 sets of WH51 in different places which you want to see reported differently.
What you now can see with different devices at ecowitt.net you can also have as different stations in Meteobridge which will then reflect different (usually excluding) combinations of your outdoor sensors.
In the MB  when posting to web sites, templates etc. or when creating reports/graphs you can combine these different sensors into one (or more) consolidated view(s).
Froggit WH4000SE (=EW 2320E) 1.6.0/GW1100 2.0.6/Froggit DP1500 1.6.8 (+EW GW1000 (4) 1.6.8 test/backup)/HP1000SE Pro (HP2551) 1.6.0/1.7.6, WH2650 WiFi (2) 1.6.8
Ecowitt WS80,WH40,WH65,WH31(5),WH31-EP(1),WN30/DP30 (1),WH32(1),WH32-EP(1),WH32B [T/H/P] (1), WH57 [Lightning] (1), WH41 [PM2.5] (2), WH51 [SoilMoisture] (5), WH45, WH55 (2)
Meteobridge Pro (2) [test,prod] 5.2 Oct 8 2021, 14568 - Blake-Larsen Sun Recorder - RPi4/weewx 4.5.1/CumulusMX 3152/MB RPi4 (2643)
Meteoshield Pro, MetSpec Rad02
Ecowitt 5763,34418;WU ISAARB3(WH4000SE), ISAARB22(HP2553);Weathercloud 3011399141, http://meshka.eu/
