Author Topic: Weather station for location with cellular only transmission?  (Read 1023 times)
Offline redstick
I am involved with selecting a weather station that is to be located at a location with only cellular access for data upload. We need to have the data from the weather station to be read by several folks at remote locations on various weather apps or Wunderground, etc. What are the options that I should be looking at? I have spoken with Davis and they have suggested the Pro 2 sensor suite (6322C) with Cellular Box (6802A) - what are other options? There is 110v power available.
Re: Weather station for location with cellular only transmission?
« Reply #1 on: June 29, 2021, 03:25:17 PM »
The Davis is a good option as you already mentioned.
Another option is the Ecowitt WS6006
https://www.ecowitt.com/shop/goodsDetail/70
Offline doubleohwhatever
Offline Mattk
« Reply #3 on: June 30, 2021, 02:58:39 AM »
Would depend on if you require a turn-key system with built-in type comms and price/constraints to match or something like a Meteobridge (MB Pro) which will connect to a variety of stations, you sort of take your pick, just add a router.
Whatever you decide don't run it directly from mains power (110v etc) but build some redundancy in a DC power supply/UPS  and power that from the mains supply
« Last Edit: June 30, 2021, 03:01:02 AM by Mattk »
Offline redstick
« Reply #4 on: July 05, 2021, 04:08:32 PM »
Any comments about reliability, I've had a Davis Pro 2 for about 7 years with the only maintenance being the need to replace the anemometer cartridge, birds really like sitting on it, ha.
« Reply #5 on: July 06, 2021, 05:13:54 AM »
I'd honestly just go with Davis. They tend to last and replacement parts are easy to get.
If the cost isn't a problem, then I'd go with their cellular solution. If you need a cheaper alternative, you could just get a wireless VP2 with either a WeatherLink Live or a console (and add a WifiLogger). You could then get a wifi hotspot router and use a M2M (machine to machine) fixed rate sim card.
Here's an example but shop around:
https://www.amazon.com/gp/aw/d/B07JCTZ3BF/
« Last Edit: July 06, 2021, 05:42:08 AM by doubleohwhatever »
Offline dfisherows
    • Dave's Horizons
« Reply #6 on: August 26, 2021, 10:33:50 PM »
Kestrel Met 6000
