Author Topic: RPi 4B MeteoPI and Davis Vantage Pro 2 Not Passing Data  (Read 1163 times)
Offline KK7GO
« on: April 20, 2021, 10:23:28 PM »
Greetings,
I have search this forum unsuccessfully to find a solution to my issue. If I missed a post, please provide link.
I upgraded to a RPi 4B, using Twister OS. I am also using WeeWx. My weather station is a Davis Vantage Pro2. The MeteoPi is the data logger. I boot the RPi via USB
I am not seeing the ttyUSB0 serial connecting. I have enabled the UART.
I thought the weewx.conf file is correct, but I may have missed something.
Any information links or ideas are appreciated.
Thanks for the help.
Ron
Offline WiFiLogger
Re: RPi 4B MeteoPI and Davis Vantage Pro 2 Not Passing Data
« Reply #1 on: April 22, 2021, 12:36:32 PM »
Did you set Serial like on screen shot?
Offline rcnz
« Reply #2 on: November 15, 2021, 02:10:36 PM »
Hi.
Similar issue.
I'd been using WeeWX with Davis logger.
I bought my WFL and Meteo-Pi together.
WFL has been working perfectly.  [tup]
I replaced it with My M-P, set the interfaces per Wojtek's screenshot, but am not seeing any output from M-P.
I'm hoping to resume using WeeWX, but need some guidance re output ports/methods, etc, please.
Robin..
Davis Vantage Pro 2
WeeWX 4.10.2 | Meteo-Pi Ethernet Logger
AWEKAS
CWOP  (MPiE Direct)
OpenWeatherMap
PWS Weather
WeatherCloud
Windy
Windfinder
WL (MPiE Direct)
WOW ((MPiE Direct)
WU
WU:
https://www.wunderground.com/dashboard/pws/IAUCKLAN159
« Reply #3 on: November 15, 2021, 03:39:00 PM »
Which serial port have you tried? ttyS0 or ttyS1? Or both?
Offline rcnz
« Reply #4 on: November 16, 2021, 06:43:49 PM »
Thanks, johnd.
I was struggling to get this sorted.
I ran wee_config --reconfigure and chose ttyS0
Then I pasted previous station data into the clean 4.5.1 weewx.conf
Problem solved!
Two days of pain fixed
 =D>
Davis Vantage Pro 2
AWEKAS
CWOP  (MPiE Direct)
OpenWeatherMap
PWS Weather
WeatherCloud
Windy
Windfinder
WL (MPiE Direct)
WOW ((MPiE Direct)
WU
WU:
