Miscellaneous Debris > Tech Corner
Fling Plus
(1/2) > >>
steviebaby59:
Does anyone use Fling Plus to update files? Mine was working fine until a few days ago. Now it won't automatically transfer updated files such as my forecast. When I run a test, everything works except delete. I haven't changed any setting on the program or in my router. My Filezilla quit retrieving the directory also. My meteobridge and my Classic FTP Plus by NCH works but I have to update my forecast manually.
saratogaWX:
I'm running Fling Plus V5.03 and it's working fine.  The issue with Delete access by FTP may be caused by a permissions configuration on your document root related to your FTP userid:password.  Since Filezilla is also having an issue, I do suspect a FTP server configuration issue, not a client issue with FileZilla or Fling.  Contact your hoster's tech support to resolve.
steviebaby59:
Thanks. I have submitted a ticket to them. Hope they can fix it.
steviebaby59:
Well I contacted them and they said there is no problem on their end. I'm wondering if it's a firewall issue. However, I haven't changed any setting on my PC or router.
steviebaby59:
When I run configuration wizard on FileZilla, this is what I get:
Connecting to probe.filezilla-project.org
Connection established, waiting for welcome message.
Response: 220 FZ router and firewall tester ready
USER FileZilla
Response: 331 Give any password.
PASS 3.61.0
Response: 230 logged on.
Checking for correct external IP address
IP 10.202.0.2 ba-cac-a-c
Response: 510 Mismatch. Your IP is 45.79.47.198, ef-hj-eh-bji
Wrong external IP address
Connection closed
[#] Next page
