Author Topic: Atlas ' UV sensörü 6'ya kadar mı? Neden  (Read 728 times)
Offline İbhlln
  • Acurite Atlas
« on: September 12, 2019, 05:59:55 AM »
Do you think atlas uv works correctly?
Offline Mabcmb
  • My WU page
Re: Atlas ' UV sensörü 6'ya kadar mı? Neden
« Reply #1 on: September 12, 2019, 11:40:57 AM »
Yes they read very low I feel !!! I have been dealing with AcuRite over mine .
Offline Mirwin275
  • AcuRite Atlas (wind ext. & lightning detector)
« Reply #2 on: September 12, 2019, 08:23:43 PM »
I can say Acurite does have good Atlas sensors that work properly now, since the warranty replacement Atlas sensor I received a couple months ago works perfectly. The first issue I had was the well known lightning problem and then the low UV readings. I have none of these issues anymore with this completely new Atlas sensor. My original Atlas I bought when they first went up for sale, which I should have known was a mistake. I should have waited longer until all of the bugs were worked out. There is hope here with getting a working Atlas is my point.
Offline Jibster
« Reply #3 on: September 13, 2019, 10:47:25 AM »
I have had three Atlases over the past several months - Acurite CS sent me a replacement after each of the first two had issues. All three of these units had/had/have very low UV readings of less than half of what I observe from other stations. Acurite Customer Service was very responsive throughout; however, low UV readings were the least of my issues so I never addressed it with Acurite.
Original Atlas: High temps/fan not running; fixed via troubleshooting w/Acurite CS.
Original Atlas: Periodic connection loss with Access - Acurite sent replacement Atlas.
Replacement Atlas: High temps/fan not running: same issue as Unit 1, however, the fan still failed to start every time it should have (unless I touched it to get it going) so Acurite sent a replacement Atlas.
Second replacement Atlas: is working well (except for the low UV)
ECOWITT GW1000 | WH32 | WS68 | WH40 | WH57
KNCRALEI888
Offline nincehelser
« Reply #4 on: September 24, 2019, 11:58:03 PM »
This is not a very realistic test, but I got a reading of 15 UV by holding a 1000 lumen LED flashlight right up against the sensor cover.
Lux maxed out at 163K.
[163K Lux, 15 UV]
CHANNEL:00 SEQ:0 DEVICE:0553 TYPE:27 SPEED:00000000 UV:15 LUX:11111111111111 0100110 0000000 CHK:7a
CHANNEL:00 SEQ:1 DEVICE:0553 TYPE:27 SPEED:00000000 UV:15 LUX:11111111111111 0100110 0000000 CHK:76
CHANNEL:00 SEQ:2 DEVICE:0553 TYPE:27 SPEED:00000000 UV:15 LUX:11111111111111 0100110 0000000 CHK:72
« Last Edit: September 24, 2019, 11:59:45 PM by nincehelser »
