Author Topic: WH2900, interceptor, MQTT - record publishing order wrong?  (Read 434 times)
Offline flygpagen
« on: January 28, 2021, 12:44:15 PM »
After the hurdles of getting my WH2900 to talk to the RBPi I have now successfully set up WeeWX with Belchertown skin, using MQTT for frequent updates of the data. In WS View I've set upload interval of the custom service to 20 seconds. When monitoring the activity I see that the timestamp of the published records are not in order, see line 1 and 4 below.
Jan 28 17:27:32 mooPi weewx[8022] INFO weewx.restx: MQTT: Published record 2021-01-28 17:27:30 CET (1611851250)
Jan 28 17:27:32 mooPi weewx[8022] INFO weewx.manager: Added record 2021-01-28 17:27:00 CET (1611851220) to database 'weewx.sdb'
Jan 28 17:27:32 mooPi weewx[8022] INFO weewx.manager: Added record 2021-01-28 17:27:00 CET (1611851220) to daily summary in 'weewx.sdb'
Jan 28 17:27:33 mooPi weewx[8022] INFO weewx.restx: MQTT: Published record 2021-01-28 17:27:00 CET (1611851220)
Is this due to the RBPi not being able to handle all packages "in time"? Some of the info from the WH2900 is also ignored, as shown when debug = 1 in weewx.conf.
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter eventrainin=0.059
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter baromrelin=29.519
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter maxdailygust=10.3
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter monthlyrainin=1.008
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter PASSKEY=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter hourlyrainin=0.000
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter freq=868M
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter model=WS2900_V2.01.12
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter dailyrainin=0.008
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter stationtype=EasyWeatherV1.5.6
Jan 28 17:20:19 mooPi weewx[6748] DEBUG user.interceptor: ignored parameter weeklyrainin=0.098
A few of these should be good to add to the database, I figure?
