Weather Station Hardware > The WxTech Dream Machine
Arduino receiver for Acurite 5-in-1, tower, and maybe lightning sensors
mangus580:
It would work for me... I could also do facebook messenger, and google hangouts too if either of those work. Send me your email address (use a private message if you prefer to not post it public)
I figure I am missing something simple, knowing my track record with things LOL
mangus580:
Thanks Joe for the quick help! Solved my issue, and it works great now!
Just to document for anyone needing it in the future....
In the D_Interrupts file, locate:
--- Code: ---void handler()
--- End code ---
and change it to:
--- Code: ---void IRAM_ATTR handler()
--- End code ---
Joe stated that something was changed in the Arduino IDE that requires this modification.
Thanks again Joe!!
mangus580:
Another update.... Some library changes have effected the code for the BMP280. If you want to use a BMP280 with this, you need to find and comment out the following lines:
--- Code: ---digitalWrite(LED_BUILTIN, !bitState); - in D_Interrupts
digitalWrite(LED_BUILTIN, HIGH); // start with LED off - E_Setup
pinMode(LED_BUILTIN, OUTPUT); // LED output - E_Setup
--- End code ---
[*] Previous page
