Author Topic: Did WU stop updateing my little radar map on my site?  (Read 933 times)
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
« on: June 06, 2020, 08:31:26 AM »
https://www.desotowiwx.com/ It looks like it has not updated since June 2nd. Anyone know of a place were I can replace the radar map with a new one?
Anthony
Offline mikeym2m
    • MikeyM's Thornhurst PA Weather
Re: Did WU stop updateing my little radar map on my site?
« Reply #1 on: June 06, 2020, 08:57:38 AM »
Looks like it's ok to me.
Update - sorry I didn't check all the settings when I checked it.
MikeyM
www.mikeymsweather.com
« Last Edit: June 07, 2020, 10:26:13 AM by mikeym2m »
Offline sacreyweather
  • Echo Valley Weather
« Reply #2 on: June 06, 2020, 10:08:43 AM »
Hi Anthony,
Yes, it looks like WU finally turned off their legacy radar. I may have a couple of replacements for you. Please look at the following. Both are from the NWS:
Upper Mississippi Valley - updates every 10 minutes
Upper Mississippi Valley Loop - a 6 image loop updated every 10 minutes.
Hope this helps,
CWOP: D2073, GR2AE, GR3, CumulusMX, CoCoRaHS: AR-SL-23
Saline Weather on Twitter
« Reply #3 on: June 06, 2020, 06:56:57 PM »
Mine has nothing past June 3rd. Does Ken have patch in the works?
« Reply #4 on: June 06, 2020, 09:22:14 PM »
Yes.  Ill check out the available maps and issue a patch tomorrow.
Offline Jester
  • Pony Up!
  • US NAVY Retired
    • Castleton Weather, Virginia Beach, VA.
« Reply #5 on: June 09, 2020, 06:46:35 AM »
Any updates on the maps Ken?
MADIS D4557
CWOP DW4557
Wunderground KVAVIRGI57
CoCoRaHS VA-VBC-13
Davis VP2+ 6163 Meteobridge 4.2
« Reply #6 on: June 09, 2020, 02:26:47 PM »
WU has completely changed the regional radar maps to have a lot more specificity (centering on a home radar site in the area).  Im still looking at options (including NWS Regional loops as a replacement).  WU has become much more trouble than its worth, and Im also strongly considering dropping WU-radar for the Base-USA as theyre still offering the static/animated radar displays but have largely discontinued other regional maps weve been using in that script and for the home page mini-displays.
The forthcoming update will likely be somewhat disruptive to existing sites as it will require changes in Settings.php, wxindex.php and flyout-menu.xml which will have to be copied to your existing site files.
Still working on it...
Offline HamiltonNJWX
    • HamiltonWx
« Reply #7 on: June 09, 2020, 04:50:41 PM »
I seriously dont know what wed do without you, Ken. Keep up the fantastic work!
« Reply #8 on: June 09, 2020, 05:00:35 PM »
I added a couple of more days to the "go see the Ridge Radar" page comment on my Announcements.
Has anyone checked their wxradar.php? The zoomed out pages have a black background and no map or data, but the zoomed in from the default seems OK on my site.
Is this problem related to the front page issue? If not, is there a fix? This used to work....
Offline Jester
  • Pony Up!
  • US NAVY Retired
« Reply #9 on: June 10, 2020, 06:28:08 AM »
Thanks Ken for the awesome work you do on your OWN time.
MADIS D4557
CWOP DW4557
CoCoRaHS VA-VBC-13
Offline Jester
  • Pony Up!
  • US NAVY Retired
« Reply #10 on: June 10, 2020, 06:30:46 AM »
Mine is the same. I think this is all related to what Ken is trying to fix.
MADIS D4557
CWOP DW4557
CoCoRaHS VA-VBC-13
« Reply #11 on: June 10, 2020, 08:10:41 AM »
Thanks for confirming this.
Offline Jasiu
    • LexMAWeather
« Reply #12 on: June 10, 2020, 09:43:31 AM »
Aeris / PWSweather has some interesting stuff via their API, but the free stuff (for PWS contributors) is limited, both for number of accesses and the actual content.
https://www.aerisweather.com/signup/pws/
I'm looking at this to replace a "other local PWS" page I have that used to rely on weather stickers.
« Reply #13 on: June 10, 2020, 02:55:44 PM »
Almost done with the fixes for the Base-USA wxindex.php page.. have to wrap up the documentation, then I'll release.
As a side note, the issue with the 'black images' for regional and usa maps in WU-radar-inc.php from icons.wxug.com appears to be a bad SSL cert
ERROR: certificate common name `www.weather.com' doesn't match requested host name `icons.wxug.com'.
Unable to establish SSL connection.
so the images are broken.
« Reply #14 on: June 10, 2020, 08:40:46 PM »
I've added the NWS Regional Radar animated images to replace the (now, non-functioning) Weather Underground Regional Radar images on the homepage just above the ajax-dashboard display.
For details, see https://www.wxforum.net/index.php?topic=39688.msg407710;topicseen#msg407710
Please respond to any issues with the update in the new topic .. I'm going to lock this thread now.
