Author Topic: WEATHER34 TEMPLATE with meteobridge options  (Read 87985 times)
Offline weather34
Re: HOMEWEATHERSTATION TEMPLATE with meteobridge options
« Reply #250 on: January 23, 2019, 01:40:21 AM »
hi attila ive added the hungarian but it wont appear for a few weeks perhaps mid February(sincere apologies) there are some other enhancements and changes coming that need to be added to the API mostly based around sun module and  averages for various other data as now it will use the internal meteobridge data as opposed to scripts to determine sunrise-set moon rise etc .these values need to be added to the API output so will wait until Boris returns ..also newer data based on hourly averages and daily averages
again using meteobridge values .
for example the number is the corresponding template number
123 [th0temp-avg60:--]
152 [th0temp-davg:--]
153 [mbsystem-lunarsegment:--]
154 [mbsystem-lunarpercent:--]
155 [mbsystem-sunrise:--]
156 [mbsystem-sunset:--]
157 [mbsystem-daylength]
and so on this will reduce use of additional scripts therefore improve loading times as the calculations are done in the meteobridge itself and readily available to use via the MBrealtimeupload.txt.
make no mistake meteobridge is a very self sufficient effective weather station device there is not a lot you cant do ..brian
Offline atika01
« Reply #251 on: January 24, 2019, 02:02:33 AM »
HI Brian,
Woooowww
Look forward to the development
Thanks for the help.
Offline weather34
« Reply #252 on: January 24, 2019, 03:43:48 AM »
hello
im sure it will be worth the wait not much you cant do with css when you sit down and think it about it ..
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #253 on: January 24, 2019, 08:20:23 AM »
Looking good Brian! =D>
Regards Simon
Offline KennyBKK
    • Khu Khot WX Station
« Reply #254 on: January 24, 2019, 11:40:11 AM »
Installed this template and couldn't figured how to get the realtime date.  The historic chart and PurpleAir is working fine.  Have check the MBrealtimeupload.txt and it seems OK.
Any place that I can check?
http://kanok.net/pws
Ambient Weather WS-1900
WUnderground, PWS - IPATHUMT2
CWOP - EW4214
Offline weather34
« Reply #255 on: January 24, 2019, 02:32:30 PM »
hello ive set it up based on your wunderground signature details but there is a lot you need to add in yourself api keys , personal info etc dont forget the essential..
Offline weather34
« Reply #256 on: January 27, 2019, 08:08:44 AM »
firstly many thank to Boris (docbee) for the update to the API ..you will need to reboot meteobridge device to get the new values to work with latest version of template(full upgrade too many changes and removals to simplify single file replacement) . there are now 158 different values produced in the MBrealtimeupload.txt file via the API
*METEOBRIDGE "MB-27012019" Version Download Information 27th January 2019 <br>
 *27th January 2019 *two options for sun position new files sun3.php and sun4.php includes an array of new data .. <br>
 *27th January 2019 *sun position module now uses meteobridge direct data (now included in MBrealtimeupload.txt output) includes new moonphases svg's,new luminance turns transparent as the luminance value decreases.. <br>
 *27th January 2019 *new livedata.php values .. <br>
 *27th January 2019 *new css for dark and light theme .. <br>
 *27th January 2019 *easyweathersetup.php removed unused settings and added new options (*old settings1.php will not work) .. <br>
 *27th January 2019 *barometer.php included fix/error for those using non standard metric configurations i.e mixing up imperial with metric (thanks to Ken True & Lightmaster).. <br>
 *27th January 2019 *weather34solaruv.php reworked for better color balance (also solaruvds.php for those who have no UV hardware).. <br>
 *27th January 2019 *new davis and NANOSD vectors for footer area.. <br>
 *27th January 2019 *new clock font Onuava Regular from daFont removes clock movement as time changes. standard monospace not used doesnt scale well.. <br>
 *27th January 2019 *eqlist.php updated with time of event positioned better.. <br>
 *27th January 2019 *includes new hungarian translation file and flag..
 *27th January 2019 *hardware information page includes new vectors ..
as always download via https://weather34.com/homeweatherstation/
« Last Edit: January 27, 2019, 08:34:45 AM by weather34 »
Offline weather34
Re: WEATHER34 TEMPLATE with meteobridge options
« Reply #257 on: January 28, 2019, 02:27:22 AM »
good morning
*IT IS IMPORTANT YOU REBOOT YOUR METEOBRIDGE DEVICE TO PICK NEW API DATA VALUES
all emails this morning issues are majority of device not being rebooted . if you are concerned that you don't want to get new version of firmware for any reason you can simply stick to current version using the internal meteobridge option.option shown below may vary on different devices .
« Last Edit: January 28, 2019, 02:32:59 AM by weather34 »
Offline weather34
« Reply #258 on: January 29, 2019, 04:06:51 AM »
good morning
firstly thank you too Josh(milehighweather) for some non metric observations have corrected average todays temp non metric output..
some minor changes to the sun3.php and sun4.php slowly losing faith in this approach and may revert back too 2017 module which did not have so many
issues.
hardware info page added vectors
 ..as always via https://weather34.com/homeweatherstation/
also just a visual thing for hardware info page slowly completing vector graphics of various supported meteobridge hardware ..more non davis hardware will appear as time goes bye..
Offline prestwickwx
« Reply #259 on: January 29, 2019, 08:32:19 AM »
good morning
issues.
Brian,
Has sun2.php been abandoned? I noticed this morning that my Daylight/Darkness panel is blank. Worked fine yesterday.
Chuck
Offline weather34
« Reply #260 on: January 29, 2019, 08:58:11 AM »
hello chuck
i will re introduce it i broke my thick skin rule of dabbling in code written by others and not spending a few days to digest how they actually work. no fault of the original code or developer merely my mistake not understanding exactly how they fully work so it looks not good for general use , i don’t particularly like the appearance of 2d context based scripts because they dont up scale well or offer a clean cut outline .. so i will revert the whole sun module back to orginals from 2017 which uses sundial34.js and pure css  . sorry for the inconvenience...brian
Offline prestwickwx
« Reply #261 on: January 29, 2019, 09:18:10 AM »
hello chuck
No problem. I have not updated to the 29th download, yet. Still using the 20th version.  I was using the sun2.php and I tried the sun1.php this morning, but both were blank.
Not a big issue - just thought I would let you know.
Chuck
Offline weather34
« Reply #262 on: January 29, 2019, 03:48:25 PM »
hello chuck
between milehighweather and myself we managed to crack the sun position module it was just updated it has sun3.php and sun4.php , he resides in your part of the world and was happy to say yes that works as one would expect..so for now i will hold out going back to sun1/2.php and see how this goes for me its me perfect and for milehighweather also the UK(PW) user who lets me update his site it is working perfectly there ..brian..
Offline lightmaster
  • MB-HWS Template Dev
    • Baxley,GA Weather
« Reply #263 on: January 29, 2019, 06:55:27 PM »
good morning
issues.
The images of the Davis Consoles are just simple static images, right? It'd be cool to get a page that's a virtual console and shows all the data like the console's screen with functional buttons beside it.
« Reply #264 on: January 30, 2019, 12:18:24 AM »
I haven't added http://www.komokaweather.com/weather/davconvp2CU.php   or  http://www.komokaweather.com/weather/davconvueCU.php
to my PWS page http://www.komokaweather.com/pws/ but should be possible in some way...
Offline weather34
« Reply #265 on: January 30, 2019, 12:21:13 AM »
good morning
yes they are just vectors for display , diagrams etc .. the functional virtual console there is a beautiful example already been around a few years ,  paul at komoka ,ca has a good example running http://www.komokaweather.com/weather/davconvp2CU.php
edit :-) has i posted paul posted above ...perhaps liase with him if want to get it up and running ..
Offline prestwickwx
« Reply #266 on: January 30, 2019, 10:47:25 AM »
hello chuck
Brian,
Just loaded the latest, 30 January. Looks great! sun3.php seems to be working fine.
Chuck
Offline weather34
« Reply #267 on: January 30, 2019, 11:46:43 AM »
awesome chuck glad its good for you have milehighweather to thank for that one his idea needed just a bit of tweaking and voila.. tomorrow there is a simple replacement for windspeeddirection.php and just two css files no need to upgrade everything.basically reworked the bft area one line of code instead of 15 ...have a nice day...brian
« Last Edit: January 30, 2019, 12:40:12 PM by weather34 »
    • Watts Bar Weather
« Reply #268 on: January 30, 2019, 10:15:53 PM »
good morning
issues.
What is that white thing between the two ISSs?
Offline 2thepoint
    • NJ WeatherCat
« Reply #269 on: January 30, 2019, 11:22:45 PM »
The white thing is a  Weatherflow Sky unit.  Haptic measurement of precip & wind.
GW1000
HP2551
GW2000
WS90
WH41B
Meteobridge/RPi4
Offline weather34
« Reply #270 on: January 31, 2019, 12:22:13 AM »
good morning
2the point is correct however i dont use it for either haptic rain or wind(dont ask me why or how does it perform) I just use the UV sensor which is gives  relatively good readings until i get a dedicated UV Davis 6490 sensor in March ..but i run i like this at the moment
« Last Edit: January 31, 2019, 12:24:13 AM by weather34 »
Offline atika01
« Reply #271 on: January 31, 2019, 06:22:03 AM »
Brian ,
Thank you very much!
I can't do "Gust" language pain.
Couldn't I insert the correct code, would you help it?
Offline weather34
« Reply #272 on: January 31, 2019, 06:23:34 AM »
many thanks to atika01
for taking the time to add in the language code for the windspeed area of beaufort ..
windspeeddirection.php + two css light/dark themes files were updated to cater for the word/phrase length variation across languages ..
Offline weather34
« Reply #273 on: January 31, 2019, 06:30:05 AM »
Brian ,
all done just uploaded update (".$lang['Gust'].")
Offline atika01
« Reply #274 on: January 31, 2019, 07:44:22 AM »
Brian,
I managed to do the translation.
Feature a, windspeeddirection.php,
Insert, $ lang ['WindRun'] = 'Wind Run' into the language file;
