Author Topic: NWS CPC USA Extremes Script Update...  (Read 3177 times)
Offline PSJohn
    • DesertWeather.com
« on: February 06, 2019, 07:23:03 PM »
FYI: the NWS CPC USA Extremes script needs an update.
Out dated URL: $url2 = "http://www.cpc.noaa.gov/products/analysis_monitoring/cdus/prcp_temp_tables/dly_glob1.txt";
NEW URL:        $url2 = "https://www.cpc.ncep.noaa.gov/products/analysis_monitoring/cdus/prcp_temp_tables/dly_glob1.txt";
Just update file or wait until Ken updates it!  :grin: ;)
John Slama
Palm Springs, California
Davis Vantage Pro 2, FARS
Online saratogaWX
Re: NWS CPC USA Extremes Script Update...
« Reply #1 on: February 06, 2019, 07:38:28 PM »
Ahh.. takes one more step
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER,0); has to be added to the curl_fetch since the cert used on www.cpc.noaa.gov does NOT include that site.  Sigh.
usaextremes.php download from https://saratoga-weather.org/usaextremes.php?sce=view
stateextremes.php download from https://saratoga-weather.org/stateextremes.php?sce=view
Thanks John for the heads-up.
Online saratogaWX
« Reply #2 on: February 07, 2019, 04:33:36 PM »
Download again this afternoon if you're still having issues.  I had to add
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST,0);
also to bypass the bad cert on www.cpc.noaa.gov.  Some server installations check/some don't (my main server doesn't check, my local XAMPP did).  This allows it to work while they still have a cert that doesn't include the specific site.
Offline SoMDWx
    • Southern Maryland Weather
« Reply #3 on: February 08, 2019, 08:19:40 PM »
Still getting N/A for the entries......
Jim
Offline PSJohn
    • DesertWeather.com
« Reply #4 on: February 09, 2019, 02:19:59 AM »
I had to use this source url: "https://www.cpc.ncep.noaa.gov/products/analysis_monitoring/cdus/prcp_temp_tables/dly_glob1.txt" in order for it to work for me.
Ken's file above uses "https://www.cpc.noaa.gov/products/analysis_monitoring/cdus/prcp_temp_tables/dly_glob1.txt".
Not sure if that's a mistake. Ken?  :-)
John Slama
Offline SoMDWx
« Reply #5 on: February 09, 2019, 08:24:09 AM »
Great catch! That worked for me! Thanks!
Jim
Online saratogaWX
« Reply #6 on: February 09, 2019, 01:51:42 PM »
 #-o   :oops: D'Oh!
You're correct.. I'd not noticed that the host had changed from www.cpc.noaa.gov to www.cpc.ncep.noaa.gov.
Corrected now in 4.03e of the scripts.
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #7 on: February 09, 2019, 02:50:48 PM »
Thanks, Ken!
W7JKG
Offline SoMDWx
« Reply #8 on: February 09, 2019, 03:14:03 PM »
Yes, Thanks Ken for all that you do and continue to do!   =D>
Jim
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
« Reply #9 on: February 09, 2019, 07:09:17 PM »
Agreed - Thanks Ken for everything you do to support this bunch  =D>
CW3699
Offline lstrip
« Reply #10 on: February 10, 2019, 04:05:50 PM »
Just updated the usaextremes and stateextremes scripts.
Shows cache updating but when i run either script, I get nothing.
https://vancamweather.com/usaextremes.php
File permission is set to 666.
What am I missing?
Larry
Online saratogaWX
« Reply #11 on: February 10, 2019, 09:07:44 PM »
The script is currently returning
500 Error. Internal Server Error.
Setting the cache file (and the script) to 755 should be enough to have it operate correctly.
Offline lstrip
« Reply #12 on: February 10, 2019, 09:52:08 PM »
Ken
I have set permissions on both the script and cache file to 755.
Still nothing when I run
https://vancamweather.com/stateextremes.php
or
Larry
Online saratogaWX
« Reply #13 on: February 10, 2019, 10:04:10 PM »
Larry, the scripts do not produce output directly.. just load some PHP variables with the data so you can use PHP print statements to put that data where you'd like to see it.
Running view-source:https://vancamweather.com/stateextremes.php and view-source:https://vancamweather.com/usaextremes.php
shows they are running correctly and setting the PHP variables with data.
You need to do something like
<?php
include_once("usaextremes.php");
print
"<p>USA Extremes for $reportDate</p>\n";
print
"<p>High Temperature<br/><br/>$usahigh</p>\n";
print
"<p>Low Temperature<br/><br/>$usalow</p>\n";
print
"<p>High Precipatation<br/><br/>$usaprecip</p>\n";
print
"<p><small>Data courtsey of <a href=\"";
print
"https://www.cpc.ncep.noaa.gov/products/analysis_monitoring/cdus/prcp_temp_tables/";
print
"\">NWS-CPC</a></small></p>\n";
for the USA version.. similarly for the stateextremes version.
Offline lstrip
« Reply #14 on: February 10, 2019, 10:30:38 PM »
Ken
Thanks for replying.
I have run the usa and stateextreme scripts for quite awhile.
The data always was displayed on the menubar below the alerts
in a box with small font and color.
Did the updated script change this?
Larry
Offline lstrip
« Reply #15 on: February 10, 2019, 10:37:31 PM »
Ken
This is an example of what I would get when I ran the scripts.
https://somdweather.com/somd_usaextremes.php
Larry
Online saratogaWX
« Reply #16 on: February 10, 2019, 10:48:19 PM »
The script I distributed has always only returned data in $variables .. never printed anything but HTML comments.
Looks like the somd_usaextremes.php script was using an earlier source.
Offline lstrip
« Reply #17 on: February 11, 2019, 03:58:22 PM »
Thanks Ken
Offline AZmonsooncats
  • Current weather conditions in North Phoenix, Ariz
  • Me & My Little Sis!!
    • Pepper Ridge North Valley  Weather and Lightning
« Reply #18 on: February 12, 2019, 07:08:46 PM »
As always Ken thanks for the update. Got this script working again now all I have to do is figure out  ](*,) how migrate my weather software to the new computer.
Jeanette
"Some dreams are in the night time, And some seem like yesterday
But leaves turn brown and fade, Ships sail away
You long to say a thousand words…but Seasons Change."
CWOP:CW3794, MesoWest: C3794, Facebook: https://www.facebook.com/PepperRidgeNorthValleyWX/
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #19 on: February 26, 2020, 07:20:55 AM »
The USA and State Extremes scripts haven't displayed the latest data since Sunday, February 23rd, Ken.  Breezy's home page displays the same problem, so I'm guessing the NWS has changed something again... :-(
Regards, Jerry Wilkins
gwwilk@gmail.com
Online saratogaWX
« Reply #20 on: February 26, 2020, 11:07:58 AM »
My version 4.03e uses
for data, and both state/USA scripts are working fine.  That was updated in Feb, 2019.
Offline gwwilk
« Reply #21 on: February 26, 2020, 01:22:00 PM »
Thanks, Ken.  That's the version and $url2 I'm using.  The obviously NWS-related problem has somehow been resolved, because the USA and State Extremes are now both populating correctly.
Appreciate your prompt attention, Ken, to this evanescent glitch.
gwwilk@gmail.com
Online saratogaWX
« Reply #22 on: February 26, 2020, 01:41:01 PM »
Next time it happens, run view-source:http://your.site.com/usaextremes.php?force=1 to force a cache reload and see the results of the fetch process.
It should show what the underlying issue is with fetching the URL.
Offline SteveFitz1
    • Tyler Texas Weather
« Reply #23 on: March 31, 2020, 06:44:44 PM »
Has anyone else noticed the USA Extremes temperatures haven't been updated since last Wednesday, 3/25/2020?
Looks like the location has changed and is now in csv format
https://www.cpc.ncep.noaa.gov/products/cadb/
Steve
« Last Edit: March 31, 2020, 06:47:26 PM by SteveFitz1 »
Offline gwwilk
« Reply #24 on: March 31, 2020, 07:25:07 PM »
I’ve also seen this, but have been otherwise preoccupied...
gwwilk@gmail.com
