I volunteered to build two systems. I had very positive experiences both times.
1.) One person had everything drop-shipped to me as he ordered it. The other accumulated all the parts and shipped everything together. Both methods worked fine. Both provided funds for incidental items, like solder, stand-offs, misc. hardware, etc. In one case, shipping costs were reimbursed, in the other, shipping was prepaid. No issues with either method. Be sure to define what it is you will provide - just bare board assembly or a turn-key system. Both stations I built for others were turn-key, including packaging in enclosures, winding and testing the antennas, and constructing the antenna enclosures and shields. But, I agreed to do it when asked, and it didn't add much additional work. It made testing easier also.
2.) I believe there is a reasonable expectation that the builder will provide a working system, even if it's a volunteer effort. This implies some good assembly and soldering skills, as well as basic troubleshooting of bad components or assembly problems. I would not have felt comfortable offering to assemble a kit if I weren't confident I could do component-level troubleshooting. Usually, a voltmeter should be sufficient. All my builds worked the first time, so I wasn't faced with the issue.
3.) I had a few spare GPS and ferrite antennas for testing and troubleshooting. Be aware that running two Red systems from the same physical location will split the detection rates between the two stations! Setting the account up was no issue - just be sure they get a login as soon as they place the kit order with Egon. Then, figure out who will register the unit once you plug in the controller to the network. I assembled the controller first, as it can be registered without the amp connected and gave time to correct any registration issues.
4.) I kind of enjoyed the optimization and assistance phase, rather than throwing the equipment "over the wall". One client graciously accepted my advice, though probably I gave much more than was needed. The other just took the system and ran with it. Both were good experiences. At some point, you may need to cut the cord. Just be sure that you specify you are offering to build an operating system, not providing lifetime tech support. The forums are there for that. Again, not an issue for me.
If you wait until Fall to make the offer, there may be fewer takers. Nothing like tornado season to stimulate interest!
Regards,
Don
WD9DMP
Come this fall with all of my summer activities out of the way, I'm toying with the idea of offering my services to help get more stations out there. I want to get some experience in making my own E Field boards first as well.
I have a few of concerns about offering my services.
1) I'm not concerned about doing it for a profit. I actually enjoy it. So all I'd be asking for is the actual costs. Buyer buys from Egon, send to me. I need a few bucks for solder, flux, etc. Buyer pays to ship back. This is the easy part.
2) All I have is a volt meter to test boards. So if something doesn't work right, I'm not sure where that'll leave me.
3) Setting up the account once board is done. I'll probably need a "test" GPS antenna and a few other parts. Then I suppose I'll need it running on my bench for a few days to make sure all is well.
4) Support: As all the messages show above, even after getting the boards done, it's not a plug and play system. You'll have to constantly tweak things. I don't want to be stuck supporting the system after I've built one.
My plan is to wait until fall when I have the time and approach one person and go from there.
