Ever since the computer meltdown and replacement, it has been one thing after the other. I've got everything fixed except Nexstorm. I got a different driver from Boltek that allows it to run as it should. Only problem is I am now getting constant noise. It cycles up to about 2200 and just stays there going up and down between about 2100 and 2200 noises. Only thing that has changed is the computer. I've adjusted squelch, sensitivity, and everything else I can think of with no luck. I'm starting to think it's the driver itself because it's actually an XP driver with different settings, not a Vista driver. Any thoughts?
