Author Topic: Meteobridge solar radiation data  (Read 844 times)
Offline Paxsman
« on: March 19, 2015, 09:09:56 PM »
It appears my Meteobridge is sending solar radiation data to Weather Underground even though I do not have a sensor installed.  The reading is always 1784.0.  Any ideas as to why this is happening?  I will have periods where no data is present and the it will just start sending the data (1784.0).  Weird!
Vantage Pro (VP1)
Belfryboy logger
Davis Vantage Pro 2
Re: Meteobridge solar radiation data
« Reply #1 on: March 20, 2015, 08:35:31 AM »
If you display Solar on your console and watch it, do you get the high readings? I would see if the console is showing the solar reading first, Meteobridge might just be sending the (bogus) info along.
If you are getting readings on the console, I would start by looking for corrosion or contaminants on the "sun" input at the ISS that might be intermittently shorting the excitation voltage to the signal line.
Offline Paxsman
« Reply #2 on: March 20, 2015, 09:05:01 AM »
I never see anything associated to the sun on the console.  I had the ISS down for service the other day and all the terminals look great...However I did not specifically look for corrosion on the sun input terminal.  Based on your suggestion I will take another look-see.
Davis Vantage Pro 2
