Weather Software => RaspberryPI Weather Software => Topic started by: nincehelser on August 15, 2019, 06:02:37 PM
Has anyone tried to use RTL_433 on a Pi 4 recently?
It works, but is awfully balky. For example sometimes the program picks it up, sometimes it doesn't. Sometimes it just takes a long time to detect the dongle.
Once it's running, everything seems OK.
I did some quick testing, using RTL_433 to receive/decode signals from a couple of Ambient TH sensors, and it seemed to perform no differently from my Pi 3s. I certainly saw no 'balkiness'.
Some others have reported the same problem.
What version of libusb did you use?
libusb-1.0-0-dev - or, at least, that's what I 'apt installed' before I built it.
Are you using the default repository?
I couldn't install libusb-1.0-0.dev directly and had to install libUSB 1.0, which is supposed to contain libusb-1.0-0.dev. The way it's behaving, I'm wondering if that's where the problem is coming from.
I have not touched my repository list. The Raspbian installation was a clean install downloaded from the official site, so it is pulling only from the two main locations on raspberrypi.org. I do have a vague memory of seeing warnings about problems if you don't use the -dev variant of libusb for compiling rtl_433.
There's some inconsistency, then. libusb-1.0.-0.dev could not be found in the repositories when I did an install.
Maybe not! If what you wrote immediately above is what you called for, it certainly would not have been found. The correct form is libusb-1.0-0-dev. You have some extra and incorrectly positioned dots in your version.
Yeah. I know. I didn't check that weird spelling in my post.
I've been using a script I wrote back in 2016 to do the actual installing.
So things just kept getting worse. It finally wouldn't run, or if it did, the data was nonsense.
I rebuilt the system with a fresh install by hitting shift while rebooting, reinstalling Raspian, and then updating.
This time my install script ran without error, and everything seems to be working fine with no balkyness.
My notes from here still work, though git and cmake were already installed.
http://www.wxforum.net/index.php?topic=30139.msg301649#msg301649
