Your site is rather 'broken' !
You have multiple <head> , <doctype= >, <body> statements.
There also problems with some of your commenting.
dashboard ajax doesn't seem to cope with windbearing 0, but it should get 'repaired' by ajaxCUwx.js
I don't believe ajaxCUwx.js is running properly, your page data is NOT updating from ajax but from the nasty meta-refresh you have.
There is an error in ajaxCUwx.js @ line #910
if(!showDateMDY) { ajaxdateformat = tdate[0]+"/"+tdate[1]+"/"+tdate[2]"; }
// should be
if(!showDateMDY) { ajaxdateformat = tdate[0]+"/"+tdate[1]+"/"+tdate[2]; }
... but it's unclear if that is the problem ...
In your page you have:
<!-- <span class="ajax" id="ajaxtime"></span> -->
<!-- <span class="ajax" id="ajaxdate">
</span> <span class="ajax" id="ajaxtime"></span>
<script type="text/javascript">
document.write('<b> - <span id="ajaxcounter"></span> </b>');
<!-- </script> -->
<script> is opened, but NOT closed, this is a mess and needs to be sorted out as to what you actually want to do !!
