Author Topic: Time Stamp  (Read 834 times)
Offline Jester
  • Pony Up!
  • US NAVY Retired
    • Castleton Weather, Virginia Beach, VA.
Time Stamp
« on: August 08, 2022, 10:59:15 AM »
I have a VP2+ connected USB to an Ambient Meteobridge uploading FTP to my provider.  For the past few months I have noticed my upload time stamp bouncing from current time to time to several min. up to an hour late and back to current time.  I can't figure out what is causing this. https://castletonweather.net/
« Last Edit: August 08, 2022, 11:01:31 AM by Jester »
MADIS D4557
CWOP DW4557
Wunderground KVAVIRGI57
CoCoRaHS VA-VBC-13
Davis VP2+ 6163
WiFi LoggerV2
Offline Gyvate
Re: Time Stamp
« Reply #1 on: August 08, 2022, 04:18:38 PM »
A FTP upload usually creates quite some load at the receiving end. Depending on your posting interval, your provider might limit these uploads or may interprete them as DDoS attacks ...
What does Meteobridge say about the FTP uploads ? Live Data --> Upload status
Offline Jester
  • Pony Up!
  • US NAVY Retired
Re: Time Stamp
« Reply #2 on: August 09, 2022, 08:05:12 AM »
[/quote
I will look after work today.
MADIS D4557
CWOP DW4557
CoCoRaHS VA-VBC-13
Davis VP2+ 6163
WiFi LoggerV2
Offline Jester
  • Pony Up!
  • US NAVY Retired
Re: Time Stamp
« Reply #3 on: August 10, 2022, 08:04:03 AM »
[/quote
The FTP uploads are fine along w/ my HTTP uploads which is set to upload every 5 sec. I also have my reltime update to PWS set to update every 5sec and it is doing the same thing there. I might need to talk to my ISP (COX) to see if they are treating my live updates out as a DDoS.  What is strange is that you think it would be a latency issue, as it is at times but my my update times on my web siite revert to past time then to current time.
MADIS D4557
CWOP DW4557
CoCoRaHS VA-VBC-13
Davis VP2+ 6163
WiFi LoggerV2
