Author Topic: web site now I need to use shift / reload to get new content ?  (Read 1270 times)
Offline Total
  • Web dude ..
    • weather station ..
Hello ALL ; On my web site at https://www.strutherslakeweather.ca , I will load fine but later when I return . The left side by Smokey the Bear loads in fine , but the right side you have to press Shift / reload to get everything up to date . Tried different browser / computers with the same result . Ideas ? thanks
Offline davidefa
Re: web site now I need to use shift / reload to get new content ?
« Reply #1 on: July 28, 2022, 05:52:47 PM »
You should have some cacheing enabled on your server that is causing this ( check in your hosting control panel )
Offline Total
  • Web dude ..
« Reply #2 on: July 28, 2022, 10:28:29 PM »
All fixed , added this to the htaccess file
# DISABLE CACHING
<IfModule mod_headers.c>
Header set Cache-Control "no-cache, no-store, must-revalidate"
Header set Pragma "no-cache"
Header set Expires 0
</IfModule>
