Author Topic: Air Quality Sensor readings different  (Read 1610 times)
Offline AlbertArnold
« on: March 27, 2022, 04:20:25 PM »
I just installed the Davis Air Quality Sensor (p/n 7210).  The device is mounted outside facing SW on my shed under an eave.  I noticed that the outside temperature and humidity is different than my Vantage Vue.  Can this be adjusted?
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: Air Quality Sensor readings different
« Reply #1 on: March 27, 2022, 04:47:23 PM »
yes you log into your weatherlink account, click the spanner icon and select the airlink device (will be a sub menu below your man device).  then goto device settings and enter your "offset" values in the Outside Temp/Hum boxes.
« Last Edit: March 27, 2022, 04:57:20 PM by ConligWX »
Regards Simon
« Reply #2 on: March 28, 2022, 08:00:15 AM »
Thank you.  I saw that as an option.  I want to wait a few days to make sure the offset is correct should I decide to make the correction.
« Reply #3 on: March 29, 2022, 03:45:16 PM »
Because I mounted to sensor facing SW, it appears that the direct sunlight may cause the temperature readings to read higher - is there something that I could put to minimize the direct sunlight for causing the higher readings.
Offline mcrossley
    • Wilmslow Astro
« Reply #4 on: March 30, 2022, 05:29:25 AM »
A sun shade?
« Reply #5 on: March 30, 2022, 11:08:53 AM »
I thought about some sort of shade to minimize direct sun from hitting the protective cover over the sensor.
