Problems with the forum? Please use Contact or PM saratogaWX with details. Thanks!
Question. Is it possible to run more than cumulusmx on the pi 4? Would like to use as plex server with USB drive but not sure if possible. Am new to pi but learning. ThanksFrank
Yes, but you have to use a command line parameter -port to change the interface port form the default 8998 on the second instance.
Ok. Not sure how to do this. trying to read about. Can you send some pointers, good reference reads so can learn how to do this?
Also make sure that the option to Stop second instance is not enabled!
Thanks, yes a plex server and mx on pi4. Would be run local at home.
