Author Topic: Weather underground- weatherflow tempest - reported pressure  (Read 1059 times)
Offline Paul.gee
    • Shot in the dark - film and photography
« on: February 21, 2022, 08:11:27 PM »
Hey, I recently added as weatherflow tempest to my Tplink meteobridge running the latest  firmware.
Everything is working as expected, except…. The reported pressure is usually 10-20hpa over what it should be on Wunderground.
The station altitude is set correctly in meteobridge and Wunderground, and the higher the station pressure the more the report values differ.
I’ve tried changing the altitudes etc without success.
Anyone know what’s going on, do I need to adjust the offset or factor formula?
« Last Edit: February 21, 2022, 08:13:11 PM by Paul.gee »
Offline davidefa
Re: Weather underground- weatherflow tempest - reported pressure
« Reply #2 on: February 22, 2022, 07:24:54 AM »
Your tempest link is showing 1031.1 hpa ( 5:10am )
Your wu link is showing 1033.19hpa ( same time )
2 hpa difference
Looking at your graph on wu of monday 21st seems like 'some changes occurred' ( not shown on tempest site ), some 'artifacts' also on temperature and solar radiation
« Last Edit: February 22, 2022, 07:26:58 AM by davidefa »
Offline gszlag
  • ..have you calibrated your barometer today?
« Reply #3 on: February 22, 2022, 10:00:02 AM »
I am not familiar with the Tempest but the weatherflow website says SLP but which one? Altimeter or METAR SLP?. If the Tempest incorporates temperature and elevation in its barometric calculations then you want to match the METAR SLP. Otherwise you want to match Altimeter.
From what I am reading, the Tempest barometer is supposed to be self-calibrating providing your elevation is correct.. Info seems to be skimpy on this subject on the weatherflow site.
According to your location, your elevation should be around 1057 m which means the offset is over 120 hPa...meaning your Altimeter setting will always be about 120 hPa higher than your current live station pressure reading.
You probably want to compare with the METAR for Calgary CYYC here:
https://aviationweather.gov/metar/data?ids=CYYC&format=decoded&date=&hours=1
If you are still way out check out the weatherflow forum or open a support ticket with weatherflow.
Maybe some other weatherflow owners on this forum can chime in.
Hope that helps a bit.
PS. I wrote a beginner's guide for calibrating barometers. It is not meant for the Tempest models  but the same general prinicples apply.
https://www.wxforum.net/index.php?topic=43477.msg442840#msg442840
Ambient Weather WS-2000
Ecowitt WS3900 console
Ecowitt GW1000/GW1100
Ecowitt WS68: Anemometer, UV/solar
Ecowitt WH40: Rain gauge
Ecowitt WH57 Lightning sensor
Ecowitt WH32E: Outside T & H sensor
Stratus Rain Gauge (manual)
Raspberry Pi 3B+ (WeeWX/CumulusMX)
Raspberry Pi Zero 2W (WeeWX/MQTT/Belchertown)
Barometer wiki: http://meshka.eu/Ecowitt/dokuwiki/doku.php?id=barometer#barometer
http://weather.glenns.ca (pwsdashboard - live)
http://weewx.glenns.ca
http://glenns.ca/cumulusmx2/index.htm
Uploading to: AWN, ecowitt.net, Weather Underground, PWSweather.com, AWEKAS, Windy.com, WOW
