Based on your first photo, it appears you have installed jumper JP1. That is used ONLY when you have a GREEN display LCD. Looking at your photos it appears you have a BLUE display LCD. You can simply pull it out and then reinsert the jumper so it makes contact only on one of the pins.
The instructions in the BO documentation (Section 4.3.1.11, page 56) shows the following:
Close Jumper 1 only if you are using the green display, otherwise, if you are using the amber or blue display, open Jumper 1.
Good luck!
