Author Topic: Frequently??? missing temp-sensor WS90 custom upload  (Read 359 times)
Offline wvdkuil
  • Wim van der kuil
« on: August 14, 2022, 09:52:29 AM »
Period: May 9 -> August 13
1 minute custom uploads, weather-devices only WiFi network, from GW2000 to a website on a dedicated windows 10 box same WiFi.
Theoretical total # of uploads 140.000.
There will be a lot of minutes without uploads.  F.i. a missing restart after windows update as I have to start the webserver myself.
Some days where I know for sure the windows box was running OK, there were 30% uploads without tempf.
In total I registred  1.980  (1.5% theoretical) nearly complete uploads.
My question, is there any reason why all other WS90 data is in the upload and the main tempf sensor is missing.
Otherwise I have to contact ecowitt for a solution.
I swapped the device with another unpacked box and will monitor the daily data.
Missing item in upload: tempf:
Thu, 28 Apr 2022 from: 10:00:10 until: 10:00:10 count for that period: 1
Wed, 04 May 2022 from: 02:03:40 until: 02:03:40 count for that period: 1
Mon, 09 May 2022 from: 18:27:53 until: 20:01:28 count for that period: 109
Tue, 10 May 2022 from: 16:49:26 until: 18:56:50 count for that period: 119
Sat, 14 May 2022 from: 06:55:37 until: 07:18:08 count for that period: 27
Sun, 15 May 2022 from: 05:51:01 until: 19:57:45 count for that period: 81
Mon, 16 May 2022 from: 05:54:53 until: 06:13:57 count for that period: 23
Wed, 18 May 2022 from: 06:13:51 until: 07:00:39 count for that period: 55
Sun, 29 May 2022 from: 05:42:26 until: 06:04:06 count for that period: 26
Fri, 03 Jun 2022 from: 19:45:08 until: 19:45:08 count for that period: 1
Sat, 23 Jul 2022 from: 20:06:25 until: 20:10:29 count for that period: 5
Mon, 25 Jul 2022 from: 14:14:28 until: 14:14:28 count for that period: 1
Tue, 26 Jul 2022 from: 11:40:33 until: 12:51:43 count for that period: 71
Wed, 27 Jul 2022 from: 08:19:22 until: 10:47:48 count for that period: 26
Thu, 28 Jul 2022 from: 05:59:41 until: 06:31:12 count for that period: 22
Fri, 29 Jul 2022 from: 05:56:14 until: 14:35:45 count for that period: 203
Sat, 30 Jul 2022 from: 20:00:39 until: 23:59:34 count for that period: 178
Sun, 31 Jul 2022 from: 00:00:35 until: 07:00:28 count for that period: 100
Tue, 09 Aug 2022 from: 06:42:35 until: 06:44:37 count for that period: 3
Wed, 10 Aug 2022 from: 11:22:46 until: 23:59:10 count for that period: 245
Thu, 11 Aug 2022 from: 00:00:11 until: 05:58:03 count for that period: 178
Fri, 12 Aug 2022 from: 11:56:32 until: 23:59:23 count for that period: 164
Sat, 13 Aug 2022 from: 00:00:24 until: 14:21:31 count for that period: 341
Total errors logged : 1980
« Last Edit: August 14, 2022, 10:07:41 AM by wvdkuil »
Online olicat
    • FOSHKplugin
Re: Frequently??? missing temp-sensor WS90 custom upload
« Reply #1 on: August 14, 2022, 10:01:42 AM »
Hi!
I also observe this with my WS90 on the GW2000 from time to time. I have not yet noticed that only tempf is missing - I monitor wh90batt to monitor a complete failure of the WS90.
And it happens from time to time that wh90batt is not sent for several minutes - the WS90 obviously has no connection to the GW2000.
So far, however, I have only noticed this. And since it happens relatively rarely, I have not yet undertaken any deeper investigations.
Does this refer exclusively to tempf in your case or could the entire WS90 also be affected?
Oliver
Offline wvdkuil
  • Wim van der kuil
« Reply #2 on: August 14, 2022, 10:06:42 AM »
Hi!
Oliver
Yes I now think the complete WS90 is affected.
I was also checking rrain_piezo  and ws90cap_volt  but it seems they are always present even if the ws90 fails.
But there are so many other sensors I test with  in the upload, that it only occured to me after posting.
Sat, 13 Aug 2022 14:21:31 +0000 = Ecowitt data received:
 Problem-94: Missing item in upload: tempf
 Problem-111: Invalid data:
    [stationtype] => GW2000A_V2.1.7
    [runtime] => 1491801
    [dateutc] => 2022-08-13 14:21:31
    [tempinf] => 79.70
    [humidityin] => 36
    [baromrelin] => 29.867
    [baromabsin] => 29.867
    [rrain_piezo] => 0.000
    [erain_piezo] => 0.000
    [hrain_piezo] => 0.000
    [drain_piezo] => 0.000
    [wrain_piezo] => 0.000
    [mrain_piezo] => 0.346
    [yrain_piezo] => 2.953
    [ws90cap_volt] => 4.1
    [ws90_ver] => 117
    [temp1f] => 87.08
    [humidity1] => 30
    [temp2f] => 87.26
    [humidity2] => 31
    [temp3f] => 50.54
    [humidity3] => 54
    [temp4f] => 51.98
    [humidity4] => 76
    [temp5f] => 80.60
    [soilmoisture2] => 25
    [pm25_ch1] => 9.0
    [pm25_avg_24h_ch1] => 10.0
    [pm25_ch2] => 5.0
    [pm25_avg_24h_ch2] => 3.7
    [pm25_ch3] => 42.0
    [pm25_avg_24h_ch3] => 25.3
    [tf_co2] => 80.06
    [humi_co2] => 38
    [pm25_co2] => 4.3
    [pm25_24h_co2] => 4.0
    [pm10_co2] => 4.3
    [pm10_24h_co2] => 4.4
    [co2] => 452
    [co2_24h] => 384
    [lightning_num] => 0
    [lightning] => 1
    [lightning_time] => 1659661195
    [tf_ch1] => 84.02
    [tf_ch2] => 75.38
    [leafwetness_ch1] => 0
    [batt1] => 0
    [batt2] => 0
    [batt3] => 0
    [batt4] => 0
    [batt5] => 0
    [soilbatt2] => 1.6
    [pm25batt1] => 6
    [pm25batt2] => 5
    [pm25batt3] => 5
    [wh57batt] => 5
    [tf_batt1] => 1.32
    [tf_batt2] => 1.32
    [co2_batt] => 6
    [leaf_batt1] => 1.44
    [freq] => 868M
    [model] => GW2000A
Offline Autofill
« Reply #3 on: August 14, 2022, 11:07:31 AM »
I wonder if its because the number has not changed, so it doesn't send an update to save 'resources'. Some devices/servers do that.
However, the last couple of firmware updates dealt with RF issues to the gateway. Perhaps this could be related?
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Offline Gyvate
« Reply #4 on: August 14, 2022, 01:14:06 PM »
why would it necessarily be a defective WS90 ? As the custom upload is created by the console, here by the GW2000...
Apart from updating the GW2000 to FW 2.1.8, you could try to also connect your WS90 to a GW1000 or GW1100 and see if the same results are produced in their postings.
