Al,
The reason I asked is that it seems to be capturing temps at other times. For instance right now (4:00 pm) fc-temps.txt reads
54.8°F,58.9°F,11/24/2010 12:39 pm
which says it was run last at 12:39. The way fc-LogTemps is written is that anytime it's run prior to noon it replaces the overnight low which is in the second position. Anytime > 12 it assumes it's capturing the day's high and replaces the first position. This was run at 12:39 so it did just that. So, it appears everything is functioning correctly except for when fc-LogTemps is doing it's job.
If you wish, you can do away with fc-LogTemps and the comparison will use values from testtags.php. If you decide to try this, fc-temps.txt must be removed from the server or else the comparison script will find it and use those values.
- Jim
