Author Topic: Theme Switch Error?  (Read 398 times)
Offline Forever
Theme Switch Error?
« on: March 26, 2023, 10:38:54 AM »
I have been getting the error below and I'm not able to track down where the bath is defined or how to fix this. Anyone have any ideas?
PHP Notice:  session_start(): ps_files_cleanup_dir: opendir(C:\Windows\TEMP) failed: No error (0) in C:\inetpub\weathercat\Settings.php on line 382
Re: Theme Switch Error?
« Reply #1 on: March 26, 2023, 03:29:37 PM »
I'm not sure (since you're running PHP on IIS/Windows), but I think the PHP settings you have for
session.save_handler   files   files
session.save_path   no value   no value
aren't quite right.  The save_handler says files, but no path is specified.
For my PHP on Apache/Linux, those values look like
session.save_path   /var/lib/php/session   /var/lib/php/session
(note the default session.save_path points to a PHP writable directory
« Last Edit: March 26, 2023, 03:34:25 PM by saratogaWX »
Offline Forever
« Reply #2 on: March 26, 2023, 05:01:18 PM »
I changed my session.save_path to C:\Windows\Temp to see if that helps. Do you know what script/file that path is defined in?
« Reply #3 on: March 26, 2023, 05:07:46 PM »
That value is in the php.ini -- none of the scripts explicitly reference it, they just use the built-in PHP session_start() function if needed.  The issue is not a scripts problem, it's a PHP configuration problem to solve.
Offline Forever
« Reply #4 on: March 27, 2023, 08:54:30 AM »
It seems it was a permissions issue on the folder causing the issue. I moved the folder and gave PHP the ability to remove the files and I think the issue is fixed.
