Hello everyone and happy new year!
I'm looking for a normal meteostation.
What I need is:
Temperature and Humidity
Wind speed and the direction
If is raining or not
Cloud presence*
Light Measure*
A way to read and store locally the data on a database via lan or wifi (I don't need the monitor).
I don't need a good accuracy
Cloud presence today:
I'm currently using a hand made device that use an infrared temperatur t check the sky temperature, much the sky temperature is equal to the ambient temperature means that clouds are present, if the sky temperature is lees of 20°C about the ambient temperature probably the sky is clear,
Light Measure:
According to
https://en.wikipedia.org/wiki/Bortle_scale I need to be able to have a good lux resolution, actually I'm using a TLS2591 that give me a 188uLux up to 88,000 Lux light measure, I have seen that some weather station have the light sensore, but I don't have any information about it's light sensore and sensitive
At the moment I have seen some ecowitt meteo station (I repeat If the temperature is more or less 1°C is not a problem) but I need to check and store the data from it via python or in any other way.
Actually I have a mysqm+ board that give me everything I need, but being an home made box sometimes I have problems with wather infiltration.
What I need is read the wheather data form a my application that will handle the telescope and the roof if the weather data are not good.
I don't care to push data to other service at the moment.
Max budget is 250€
Any advices??
