Author Topic: Trouble Reaching Web Interface - wifi Logger 1 - FW=2.38  (Read 665 times)
Offline fjordey37
« on: November 27, 2022, 03:21:24 PM »
#1 the backend of the logger works as it should - all uploads are working normally, and I can connect with weatherlink software using the IP.
With that our of the way, I have been trying to get to the web interface using several different browsers and it just hangs - eventually the browser will just time-out.
Now since I can connect through the weatherlink software using the IP - I can rule out a bad ip address.
I have turned off all pop-up and add blockers (never had to before) and the station at my current location works fine with no intervention.
Of course I'm not local to that station (it's over 5 hours away) so it's not like I can just go unplug or manually reset.
any thoughts or ideas I may have missed, is there some way to send a reboot command with-out the web interface?
-Mark
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Re: Trouble Reaching Web Interface - wifi Logger 1 - FW=2.38
« Reply #1 on: November 27, 2022, 03:26:13 PM »
I ran into just the same scenario a few weeks back. Click white button on WFL solved it. I don't know any other way.
Offline fjordey37
« Reply #2 on: November 27, 2022, 03:40:25 PM »
yeah not an option being 300 miles away from the white button...  :sad:
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #3 on: December 08, 2022, 12:49:13 PM »
It may be of interest to you or others that last evening the both of my WFL 2 loggers were unreachable on the LAN.
They were still doing their upload jobs.
I went to bed and this PM I am able to access. They righted themselves.
Offline BigAlT
« Reply #4 on: December 08, 2022, 04:03:08 PM »
With one of my wifi loggers 2’s  I have the same problem. Approximately once a week It isn’t reachable from a browser unless I press the white button. However, I can ping it from my Fing Box and it does respond to all the pings.
 I upgraded the firmware to 2.41 and it didn’t make any difference.
« Last Edit: December 08, 2022, 04:17:04 PM by BigAlT »
Davis Vantage Vue ISS & Console with WiFi Logger 2
2nd Davis Vantage Vue Console with WiFi Logger 2
Davis Vantage Pro2 Console with Meteobridge Nano SD
Davis Weather Envoy with USB Logger connected to RPi 3B+ running WEEWX
WeatherFlow Smart Weather Station
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #5 on: December 08, 2022, 11:15:50 PM »
I didn't PING but they both showed connected at expected IP address according to Tenda WiFi app but not showing in browser. One on 2.38 and one 2.42
