Two problems here, but one fix should get you going again. Doing a
view-source:http://pennlake.us/wxforecast.php?z=1 helps to debug these things.
1) The call to fetch the meta data is failing.
!-- advforecast2.php (JSON) - V5.17 - 15-Jul-2020 on PHP 7.3.22-->
<!-- RAW NWS URL: http://forecast.weather.gov/MapClick.php?lat=42.8534&lon=-74.9854&unit=0&lg=english&FcstType=text&TextType=2 zone=NYC043 -->
<!-- meta info re: point='42.8534,-74.9854' zone='zones' metacache= './cache/forecast-NYC043-1-geojson-meta.txt' -->
<!-- metaZoneURL='https://api.weather.gov/zones/forecast/NYC043' -->
<!-- meta cache ./cache/forecast-NYC043-1-geojson-meta.txt age=4:47:23 h:m:s -->
<!-- loaded meta info from ./cache/forecast-NYC043-1-geojson-meta.txt age=4:47:23 h:m:s -->
<!-- getting metadata for forecast zone from https://api.weather.gov/zones/forecast/NYC043 -->
<!-- logged 'Fetch fail' to './cache/advforecast2-log-2020-09-21.txt' -->
<!-- curl fetching 'https://api.weather.gov/zones/forecast/NYC043' -->
<!-- HTTP stats: RC=404 dest=184.84.228.8 port=443 (from sce=173.230.251.210)
Times: dns=0.029 conn=0.039 pxfer=0.077 get=0.119 total=0.196 secs -->
<!-- headers returned:
HTTP/2 404
server: nginx/1.16.1
content-type: application/problem+json
access-control-allow-origin: *
access-control-allow-headers: Feature-Flags
x-request-id: 1f87c9f5-ba1c-4e7f-bf1e-446f6d7663bd
x-correlation-id: 1e934810
x-server-id: vm-bldr-nids-apiapp5.ncep.noaa.gov
pragma: no-cache
content-length: 264
x-akamai-request-id: 1e934810.b59f7ae
cache-control: private, must-revalidate, max-age=2591944
expires: Wed, 21 Oct 2020 14:54:21 GMT
date: Mon, 21 Sep 2020 14:55:17 GMT
x-cache: TCP_MISS from a96-17-11-212.deploy.akamaitechnologies.com (AkamaiGHost/10.1.5-30889964) (-)
x-edge-request-id: b59f7ae
vary: Accept,Feature-Flags,Accept-Language
strict-transport-security: max-age=31536000 ; includeSubDomains ; preload
The code doesn't explicitly handle such errors - just assumes you got good data.
if (!isset($META['zoneName'])) { // no zone data.. load it
$Status.= "<!-- getting metadata for forecast zone from $metaZoneURL -->\n";
$rawhtml = ADV_fetchUrlWithoutHanging($metaZoneURL);
$stuff = explode("\r\n\r\n",$rawhtml); // maybe we have more than one header due to redirects.
$content = (string)array_pop($stuff); // last one is the content
$headers = (string)array_pop($stuff); // next-to-last-one is the headers
$rawPJSON = json_decode($content, true); // parse the JSON into an associative array
$PJSON = $rawPJSON['properties']; // geojson format
So when you get to that last line there, you encounter the error because "properties" is not set.
2) The reason it is failing is because you have a county code there instead of a zone code. It needs to be a zone code. You can fix this in Settings.php
$SITE['NWSforecasts'] = array( // for the advforecast2.php V3.xx version script
// use "Zone|Location|Point-printableURL", as entries .. first one will be the default forecast.
"PAZ047|Penn Lake Park |http://forecast.weather.gov/MapClick.php?lat=41.1131&lon=-75.7749&unit=0&lg=english&FcstType=text&TextType=2",
"NYC043|Richfield Springs|http://forecast.weather.gov/MapClick.php?lat=42.8534&lon=-74.9854&unit=0&lg=english&FcstType=text&TextType=2",
"PAZ055|Stroudsburg|http://forecast.weather.gov/MapClick.php?lat=40.9868&lon=-75.1946&unit=0&lg=english&FcstType=text&TextType=2",
"PAZ006|Coudersport|http://forecast.weather.gov/MapClick.php?lat=41.7748&lon=-78.0206&unit=0&lg=english&FcstType=text&TextType=2",
Just plug in the correct zone code for Richfield as you've done for the others.
