Author Topic: UPdated wxGOES16&17(18)-HAniSLoops with New Image Series (& More!)  (Read 7302 times)
Offline gwwilk
  • Southeast Lincoln Weather
Re: UPdated wxGOES16&17-HAniSLoops with New Image Series (& More!)
« Reply #25 on: March 15, 2022, 09:00:24 AM »
After wrestling with and finally succeeding in updating my GIF loops scripts yesterday, it was comparatively easy today to update my HANIS-animated GOES16&17 scripts to include the 'FireTemperature' and 'Lightning' images.
The updated scripts are available on my script page.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline 92merc
  • BismarckWeather.net
« Reply #26 on: March 15, 2022, 10:01:49 AM »
I noticed on the GOES16, the CO2 Longloop works on Hanis version, but not on the regular GIF version.
« Last Edit: March 15, 2022, 10:03:56 AM by 92merc »
Offline gwwilk
« Reply #27 on: March 15, 2022, 10:07:55 AM »
I guess that's because there's no longer an animated CO2 GIF being produced by NESDIS.
Thanks for the heads up!  I'll remove the link later today.
Update 12 noon CDT: Link removed in updated ZIP.
« Last Edit: March 15, 2022, 01:00:52 PM by gwwilk »
gwwilk@gmail.com
Offline gwwilk
« Reply #28 on: March 16, 2022, 06:58:07 AM »
There were problems with the GOES16&17-HAniS Loop scripts that have been addressed in the latest scripts on my scripts page. Namely the page crashed when the satellite band was changed!  No more.
The advantage of the HAniS Loops is that a full complement of satellite bands is available, except I just realized I need to add 'Dust'.  Later...
Update 8:00am CDT:  'Dust' now incorporated into the latest HAniS Loop scripts available as above.
« Last Edit: March 16, 2022, 08:58:37 AM by gwwilk »
gwwilk@gmail.com
Offline weatherdoc
    • Willowsford Farm Weather
« Reply #29 on: March 17, 2022, 12:16:34 PM »
Jerry - these are very nice updates. Thanks for your work. Previously I was only using your HAniS GOES-16 script but realized it's also good to have the lower bandwidth GIF loop. While I was at it, I added GOES-17 to my website. Bill
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #30 on: March 17, 2022, 01:10:12 PM »
As always, thanks for sharing your work and the updates.  I tweaked your scripts just a little bit, taking an approach similar to the one you took with the tropical weather scripts you published, using a table to create "tabs" making it easy for users to switch between GOES-16 and GOES-17 (I borrowed and retrofitted code snippets from your NWSHurricaneCenter script) .  Example at https://camwx.com/wxGOES17-HAniSLoops.php.
Thanks again!
Grant Miles
Camarillo, CA, USA
Owner/Admin - CamWX.com
SKYWARN Spotter
Station Hardware: Davis Vantage Pro2 Plus w/ 24hr FARS
Station Software: Weather Display, Weather Message, FWI Calculator, StartWatch, with social media & messaging automation using Make.com, Twilio, and Brevo.
Offline gwwilk
« Reply #31 on: March 17, 2022, 02:55:26 PM »
Thanks again!
Nicely done, and you're welcome.  Glad you found the scripts useful.  Would you like to share your script?  It's very helpful.
gwwilk@gmail.com
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #32 on: March 17, 2022, 03:00:08 PM »
Of course I should have thought of that.   #-o I keep forgetting that script isn't visible to the public.
Here's the package... all credit goes to Jerry, I just put the pieces together a little differently.  Jerry, only modifications were to the wxGOES16-HAniSLoops.php and wxGOES17-HAniSLoops.php.  I left everything else alone.
« Last Edit: March 17, 2022, 03:19:56 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline gwwilk
« Reply #33 on: March 17, 2022, 04:46:42 PM »
Thanks for the scripts!  I've renamed your scripts *Tabbed.php and incorporated them into a fresh ZIP on my scripts page.
Nice work!
gwwilk@gmail.com
Offline mikeym2m
    • MikeyM's Thornhurst PA Weather
« Reply #34 on: March 17, 2022, 05:25:06 PM »
Already incorporated. A big Thanks to Jerry and K6GKM!   [tup]
MikeyM
www.mikeymsweather.com
Offline gwwilk
« Reply #35 on: March 18, 2022, 05:54:16 PM »
Freshly debugged scripts are available on my scripts page.  The GOES16 'CONUS' Continental US view  contained an <iframe> height that was incorrect, which I never noticed because I defaulted to 'umv' Upper Mississippi Valley on the script.  I've also updated the original GOES16 script.
gwwilk@gmail.com
Offline gwwilk
« Reply #36 on: March 21, 2022, 03:33:03 PM »
 #-o Unfortunately I mangled the GOES16-HAniSLoops-SA version, as Tom Abell so kindly pointed out privately.
A new script set for the GOES16 HAniSLoops is available on my scripts page.
Replace all of the scripts for optimal results...
gwwilk@gmail.com
Offline gwwilk
« Reply #37 on: March 22, 2022, 09:27:29 AM »
My gyrations with these scripts continue. :oops:  The GOES16-17 Tabbed version wasn't updated, so the GOES16 display went SA (huge) within the template!  Not good.  #-o
This has been corrected in the latest version while some tweaks were made to the GOES16 HAniS version as well.
As usual you can get the updates on my scripts page.
Don't forget to set your preferences in the main scripts before uploading those you use.
gwwilk@gmail.com
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
« Reply #38 on: April 10, 2022, 07:23:29 PM »
Hi All,
I started to work on this for my web page and made some mods to get the tabs working between GOES 16 & 17.
See what I have done so far: http://www.dwayneyamato.com/wx/wxGOES16-HAniSLoopsTabbed.php
I see that when going from 17 to 16 there is an over run on this area on 16 on this snap shot.
The yellow is the over run and in the red is where I think it is wider than what is on 17.
Wonder where I can edit 16 to make it narrower to solve the over run on this line?
It is not public yet on my Nav/Menu.
Thanks for suggestions and or recommendations.
Aloha,
--Stan Y.
  Maui, Hawaii
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
Offline gwwilk
« Reply #39 on: April 10, 2022, 07:58:33 PM »
I see that with Firefox, Stan, but not with Brave/Chrome which was my testing browser.
The dimensions of the dropdown selectors are overwide, e.g. Satellite Band is 198px wide in Brave but 213px wide in Firefox.  This problem is carried through the remainder of the selectors producing the overrun visible in Firefox.
I'll need to ponder this a while...
gwwilk@gmail.com
Offline Silversword
  • --Stan Y.
« Reply #40 on: April 10, 2022, 08:35:08 PM »
Thanks Jerry for your reply.
I just used Chrome and compared with FF, it is the same with my Chrome with that over run and the that red circled place from my snap shot is wider then GOES 17 compared with GOES 16.
Also I am using Windows 10 and FF with the latest updates. Not sure about my Chrome for the current update.
Thanks again for all of your support with your scripts.
Stay healthy and safe with you and your family.
Aloha,
--Stan Y.
  Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline gwwilk
« Reply #41 on: April 11, 2022, 09:31:05 AM »
After considerable flailing around, I finally found where to fix the offending code:  I needed to specify a font-size for the dropdown labels!  Once that was done, the dropdowns no longer overrun the space allotted.
A new zip is available on my scripts page.  In order to create a new ZIP all of the files have been touched (except HAniS), but the important one is 'inc-wxGOES16-HAniSLoops.php' where the necessary changes are found.
gwwilk@gmail.com
Offline Silversword
  • --Stan Y.
« Reply #42 on: April 11, 2022, 11:47:46 AM »
Thanks Jerry for the fix.
Working on your site and now to work on mine.
Aloha,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline gwwilk
« Reply #43 on: April 11, 2022, 01:39:03 PM »
To help prevent stale versions I also updated the 'wxGOES16-17-HAniSLoopsTabbed.zip' to include the updated GOES16 scripts.  It's found in the usual place.
gwwilk@gmail.com
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #44 on: April 12, 2022, 01:37:54 PM »
One more very minor, more-OCD-than-anything-else tweak from me if you'll have it... Loading remote images from NHC every time for the color flourish on the tabs never really sat right with me, so I saved them locally and updated the code.
« Last Edit: April 12, 2022, 02:06:08 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline gwwilk
« Reply #45 on: April 12, 2022, 05:25:24 PM »
Tweak appreciated and added to a modified ZIP.  The two images need to be placed in the site's /images folder, and the two 'Tabbed.php' scripts are the only ones that need to be updated.
gwwilk@gmail.com
Offline Silversword
  • --Stan Y.
« Reply #46 on: April 21, 2022, 02:39:57 PM »
Hi All,
I updated my site with this latest update.  Seems to be working for my.  I just modified the title of 16 and 17 to see which satellite is being looped. Kinda redundant as it shows in the Tabbed area as well.
Check mine out at http://www.dwayneyamato.com/wx/ in the flyout menu of Radar/Satellite Loops on my dashboard site.
Thanks Jerry and all for your inputs.
Aloha,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline gwwilk
« Reply #47 on: April 25, 2022, 07:16:02 AM »
Just a heads up:  Since 1:46 UTC 2022/04/25 NESDIS hasn't been able to serve current GOES16 or GOES17 images.  The scripts are serving stale images instead.
They're working on a fix...
« Last Edit: April 25, 2022, 07:18:13 AM by gwwilk »
gwwilk@gmail.com
Offline gwwilk
« Reply #48 on: April 25, 2022, 09:35:13 AM »
NESDIS is again serving current images!
gwwilk@gmail.com
Offline gwwilk
Re: UPdated wxGOES16&18-HAniSLoops with New Image Series (& More!)
« Reply #49 on: August 05, 2022, 09:28:14 AM »
Revised GOES16&18-HAniSLoops scripts are up on my scripts page.  The tabbed versions are also available.
NESDIS is displaying the images labeled as 'GOES18', hence the new script names.
gwwilk@gmail.com
