Ahh... several issues. Some older scripts are causing the stalling at load. Running check-fetch-times.php?show=versions shows multiple scripts in particular need updating:
advforecast2.php Need update to V5.13 - 2019-08-08
get-metar-conditions-inc.php Need update to V1.18 - 2019-11-07
nws-alerts.php Need update to V1.43 - 2019-05-14
and especially:
get-USNO-sunmoon.php Need update to V3.03 - 2019-11-24
The latter is due to aa.usno.navy.mil is 'offline' through May due to a site redesign. It's causing the majority of the delay in page load
<!-- get-USNO-sunmoon.php - Version 3.02 - 23-Nov-2018 -->
<!-- refetch seconds=1 -->
<!-- loading ./cache/USNO-moondata.txt from https://api.usno.navy.mil/rstt/oneday?date=04/24/2020&coords=26.565629,-80.162173&tz=-4 -->
<!-- curl fetching 'https://api.usno.navy.mil/rstt/oneday?date=04/24/2020&coords=26.565629,-80.162173&tz=-4' -->
<!-- curl Error: Connection timed out after 30000 milliseconds -->
You can get all the updates by using the
update tool since 04-Feb-2019 with the Base-USA, MB-plugin
Looking at Settings.php, I think you have
$SITE['NWSforecasts'] = array( // for the advforecast2.php V3.xx version script
// use "Zone|Location|Point-printableURL", as entries .. first one will be the default forecast.
"FLC099|Lake Worth|http://forecast.weather.gov/MapClick.php?CityName=Lake Worth&state=FL&site=MTR&textField1=26.565629&textField2=-80.162173&e=1&TextType=2",
"FLC086|Miami Dade|http://forecast.weather.gov/MapClick.php?CityName=Miami&state=FL&site=MTR&textField1=25.5516&textField2=-80.6322&e=0&TextType=2",
"FLC011|Fort Lauderdale|http://forecast.weather.gov/MapClick.php?CityName=Fort Lauderdale&state=FL&site=MTR&textField1=26.122&textField2=-80.1373&e=0&TextType=2",
and
$SITE['noaazone'] = 'FLC099'; // used for NOAA advisories and advforecast2.php zone forecasts
and
$SITE['NWSalertsCodes'] = array(
"Palm Beach County|FLC068|FLC067",
// "Santa Cruz Mtns|CAZ512|CAC081|CAC085|CAC087",
"Fort Lauderdale|FLC011|FLC086",
// "Monterey|CAZ530|CAC053",
// "South/East Bay|CAZ508|CAC081",
// "San Mateo Coast|CAZ509|CAC081",
// "San Francisco|CAZ006|CAC075"
I think you misunderstand what should be in the $SITE['NWSforecasts'] array.. you have FL
Cnnn codes (County codes) and they should be FL
Znnn (Forecast Zone codes). Likewise, in the $SITE['noaazone'] , should be a Zone code.
and in $SITE['NWSalertsCodes'], it's ok to have County codes, but you should have at least one Zone code in each line.
Hope this helps...
