I have given this a try and this is what I get. My data files are uploaded. Let me know what I have overlooked.
http://lebanontnwx.org/sivu2.php
Thanks.
Bob
If the settings are correct sivu2.php should at least display some data, more then the time lines.
There is no way we can now see what is wrong, so we have to enable the error display .
Depending of your version search for the first <?php in the sivu2.php script, you will find that near:
<!-- HEAD START -->
<!-- Put this part inside <head> and </head>-tags, needed on ALL pages using 3in1 -->
<?php
Change that line to
<?php ini_set('display_errors', 'On'); error_reporting(E_ERROR ); $lang='en';
Now a large amount of notices, warnings and hopefully one or two errors should be displayed.
We need the error messages from sivu2.php, if none then we have to switch error display on in the next script and so on.
It will probably help is you make a
copy of wxall.settings.php as wxall.settings.txt and add that as an attachement to your next post.
=== Times in lastret.txt
Check my posts about this item, last one at
@tstorm.
Also change the wxall.lastret.php as your date times are also of with 25 minutes.
0 2015-01-16_12:55_UTC
0 2015-01-16_13:25_UTC
Line 10should be added in wxall.lastret.php with:
$from = array (':25_UTC',':55_UTC'); $to = array (':00_UTC',':30_UTC'); $csv = str_replace($from,$to,$csv);
Wim
