Author Topic: USA Extremes  (Read 19212 times)
Offline cospringswx
    • Colorado Springs Weather
USA Extremes
« on: September 20, 2012, 02:31:44 AM »
Is anyone else having problems with the USA Extremes script not working?
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline William Grimsley
    • Newton Poppleford Weather
Re: USA Extremes
« Reply #1 on: September 20, 2012, 02:34:43 AM »
Hi hayskswx,
If that is "wxworldextremes.php" then No. Not having problems with the U.S.A or any other scripts.
Will
http://www.newton-poppleford-weather.co.uk
Davis Vantage Vue - Cumulus v1.9.4 (1084)
Weather Underground: IDEVONEX12
Met Office WOW: 717144
PWS Weather: ENG128597
Offline Dr Obbins
Re: USA Extremes
« Reply #2 on: September 20, 2012, 06:39:35 AM »
Currently - Yes.
Offline n7xrd
    • Kamiah Weather
Re: USA Extremes
« Reply #3 on: September 20, 2012, 08:31:34 AM »
Yes mine is blank also!
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
Re: USA Extremes
« Reply #4 on: September 20, 2012, 10:47:46 AM »
Same here - sidebar displays N/A for the three items, but wxworldextremes appears OK.
W7JKG
Offline cospringswx
Re: USA Extremes
« Reply #5 on: September 20, 2012, 10:52:22 AM »
Thanks. Mine says N/A as well.
Ryan
Davis Vantage Vue
Re: USA Extremes
« Reply #6 on: September 20, 2012, 10:53:42 AM »
Ah, so you are using a different script to mine. Well, wxworldextremes.php is definitely working.
Will
Re: USA Extremes
« Reply #7 on: September 20, 2012, 12:43:24 PM »
likewise, here.
Offline gwwilk
  • Southeast Lincoln Weather
Re: USA Extremes
« Reply #8 on: September 20, 2012, 01:25:40 PM »
Odd, that. :shock:  My sidebar is reporting the same extremes as World Extremes.  Go figure.
Regards, Jerry Wilkins
gwwilk@gmail.com
Re: USA Extremes
« Reply #9 on: September 20, 2012, 01:26:49 PM »
Hmmm, this seems very strange. Hope it fixes soon Yankies!
Will
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
Re: USA Extremes
« Reply #10 on: September 20, 2012, 03:45:08 PM »
The URL has changed. Ive been messing with the new one and got the N/A part removed, now just working on getting the data to display.
I think im getting close on it, if I do figure it out, ill pass along the changes.
Software: WeatherDisplay
Offline cospringswx
Re: USA Extremes
« Reply #11 on: September 20, 2012, 03:47:20 PM »
Awesome Thanks!
Ryan
Davis Vantage Vue
  • Mark
Re: USA Extremes
« Reply #12 on: September 20, 2012, 09:19:14 PM »
I got stuck on part of the code, so I've asked Ken to help me. When its been fixed I'll post the new script for this.
Offline SoMDWx
    • Southern Maryland Weather
Re: USA Extremes
« Reply #13 on: September 21, 2012, 09:01:34 AM »
Accuweather has embeeded this information as part of an ASP page that parses an XML file.
Done!  http://somdweather.com/usaextremes.php
Here is the snippet of PHP5 code to do this:
<?php
    $myextremes = simplexml_load_file('http://www.accuweather.com/adc2004/pub/includes/headlines/extremes.xml');
    $usahigh =  $myextremes->maxTemp->tempF . " F <br/>" . $myextremes->maxTemp->city . ", " . $myextremes->maxTemp->state;
    $usalow =  $myextremes->minTemp->tempF . " F <br/>". $myextremes->minTemp->city . ", " . $myextremes->minTemp->state;
    $usaprecip =  $myextremes->maxPrec->precIN . " in<br/>". $myextremes->maxPrec->city . ", " . $myextremes->maxPrec->state;
Hope this helps!
Jim
Offline cospringswx
Re: USA Extremes
« Reply #14 on: September 21, 2012, 10:32:46 AM »
Jim do I replace my usaextremes.php file with the script that you posted?
Ryan
Davis Vantage Vue
Offline SoMDWx
Re: USA Extremes
« Reply #15 on: September 21, 2012, 10:38:27 AM »
Ryan,
  The little snippet of code that I provided is the heart of the script. The variables $usahigh,$usalow, and $usaprecip actually hold the data. You can use these variables and format them to what you need. I suspect Ken or someone else will roll something similar into the pre-existing usaextremes.php file or develop a new one.
Jim
Offline cospringswx
Re: USA Extremes
« Reply #16 on: September 21, 2012, 10:39:47 AM »
Ok Thanks Jim.
Ryan
Davis Vantage Vue
Re: USA Extremes
« Reply #17 on: September 21, 2012, 10:53:30 AM »
Glad you have got your USA Extremes sorted! Might have turned into a tragedy!
Will
  • Mark
Re: USA Extremes
« Reply #18 on: September 21, 2012, 06:30:02 PM »
Jim
Ken is working on getting this data from WU since Accuweather is pretty strict on sharing there info.
Re: USA Extremes
« Reply #19 on: September 21, 2012, 10:55:32 PM »
At Mark's request, I've redone the usaextremes.php script from relayweather to use WeatherUnderground as the source for the data.
Here's the code for usaextremes.php
<?php
#   Project:    USA Extremes
#   Module:     usaextremes.php
#   Purpose:    Provides USA Extremes for Web page display
#   Authors:    Michael (michael@relayweather.com)
#               Ken True (webmaster@saratoga-weather.org) V2.01
# Usage:  Place the following on your webpage
# CHMOD 666 for cacheFile2.php
# include_once('usaextremes.php');
# Then call the following tags within the page where you would like them displayed:
# $usahigh
# $usalow
# $usaprecip
#  Note: allow_url_fopen = on
#    in your php.ini is required to run this script.
// version
// Version 2.00 - 14-Sep-2010 - initial release
// Version 2.01 - 21-Sep-2012 - adapted for WeatherUnderground use - K. True
$usaextremesverion "2.01";
echo
"<!-- USA Extremes Script Version $usaextremesverion. -->\n";
//SETTINGS START HERE////////////////////////////////////////////////////////
// Site to Parse
$url2 "http://www.wunderground.com/climate/extremes.asp";
// Set the time zone
$ourTZ 'America/Los_Angeles';
// Name of cache file  --  This file must be set to CHMOD-666
$cacheFile2 "usaextremesCache.php";
// Age of cache file before re-fetch caching time, in seconds (3600 = 1 hour)
$cache_life '3600'
//END SETTINGS///////////////////////////////////////////////////////////////
if (file_exists($cacheFile2)) {
$filemtime filemtime($cacheFile2);
$filesize filesize($cacheFile2);
    if (
== $filesize){
$filemtime 0;
} else {
$filemtime 0;
//   open the cache file and write the new data and then close the file.
$forceRefresh = (isset($_REQUEST['force']))?true:false;
$current_time time();
$cache_age $current_time $filemtime;
if (
$forceRefresh or $cache_age >= $cache_life){
$html2 implode(' 'file($url2));
$fp2 fopen($cacheFile2'w');
fwrite($fp2$html2);
fclose($fp2);
   echo
"<!-- The cache life HAS expired and fresh data re-wrote the cache file -->\n";
} else {
   echo
"<!-- The cache life HAS NOT expired and fresh data was not written to the cache file -->\n";
// Open the cache file, read it, then close it
$handle2 fopen($cacheFile2"r");
$html2 fread($handle2$filesize);
fclose($handle2);
//Finds USA High
preg_match_all('|<div id="highTemp"[^>]*>(.*)</div>|Uis'$html2$matches);
//  print "<pre>\n".print_r($matches,true)."</pre>\n";
if(isset($matches[1][0])) {
$hightable $matches[1][0];
preg_match_all('|<td>(.*)</td>|Uis',$hightable,$matches);
$usahigh trim(preg_replace("|\n|is",'',strip_tags($matches[1][2]).'<br/>'.strip_tags($matches[1][0])));
  print
"<!-- usahigh='$usahigh' -->\n";
} else {
$usahigh 'N/A';
//Finds USA Low
preg_match_all('|<div id="lowTemp"[^>]*>(.*)</div>|Uis'$html2$matches);
$lowtable $matches[1][0];
preg_match_all('|<td>(.*)</td>|Uis',$lowtable,$matches);
$usalow trim(preg_replace("|\n|is",'',strip_tags($matches[1][2]).'<br/>'.strip_tags($matches[1][0])));
  print
"<!-- usalow='$usalow'-->\n";
} else {
$usalow 'N/A';
//Finds USA High Precip
preg_match_all('|<div id="precip"[^>]*>(.*)</div>|Uis'$html2$matches);
$raintable $matches[1][0];
preg_match_all('|<td>(.*)</td>|Uis',$raintable,$matches);
$usaprecip trim(preg_replace("|\n|is",'',strip_tags($matches[1][2]).'<br/>'.strip_tags($matches[1][0])));
  print
"<!-- usaprecip='$usaprecip' -->\n";
} else {
$usaprecip 'N/A';
print
'<!-- $filemtime = '.$filemtime.' $cache_age = '.$cache_age.' seconds.' " -->\n";
print
"<!-- Cache refresh rate = $cache_life seconds.  Cache age = $cache_age seconds. -->\n";
After installing, you may need to run it with ?force=1 to clear the cache and reload the page from Wunderground.
Let me know how it works for you...
Best regards,
Ken
Offline n7xrd
    • Kamiah Weather
Re: USA Extremes
« Reply #20 on: September 21, 2012, 11:05:31 PM »
 :grin:  Thanks Ken seems to working great!!!!
  • Mark
Re: USA Extremes
« Reply #21 on: September 21, 2012, 11:12:36 PM »
Works great... Thanks for your time in fixing this script Ken.
Offline cospringswx
Re: USA Extremes
« Reply #22 on: September 21, 2012, 11:38:38 PM »
Thanks as always Ken.
Ryan
Davis Vantage Vue
Offline jgillett
Re: USA Extremes
« Reply #23 on: September 22, 2012, 12:19:12 AM »
Works great, Ken - as always!
Thank you :!:
W7JKG
Offline Maumelle Weather
    • Maumelle Weather
Re: USA Extremes
« Reply #24 on: September 22, 2012, 07:27:43 AM »
Hi Jim,
Thanks for the code snippet!!!
GR2AE, GR3, Cumulus
