Author Topic: Fire Danger Script  (Read 5930 times)
Offline dre
    • Weather by the Bay
Fire Danger Script
« on: January 01, 2008, 09:37:27 PM »
Hi All,
I'm new to weather and this forum.  I'm in the process of setting up my web site,
http://www.weatherbythebay.com
and would like to list the local fire danger.  I've downloaded the fire danger script from SLOweather, which says that it needs a file called stickertags.txt.  I've looked at Anole's web site, but was unable to find out abot it.  Can anyone help me?
Offline capeweather
    • http://www.capeweather.com
Re: Fire Danger Script
« Reply #1 on: January 01, 2008, 10:30:26 PM »
Chris
Cape Coral, Florida
Offline SLOweather
    • http://www.sloweather.com
« Reply #2 on: January 01, 2008, 10:57:04 PM »
Hi Dre, and welcome to wxforum.
Before you embark on this, make sure that your web server is running PHP. You need it to run the script.
Since I was already using Anole's Weather Graphic script, and his data file has the required weather data in it already, I use that data in the Fire Danger Script.
You appear to be using WeatherLink software.
Anole's weather graphic download page is at http://scripts.anolecomputer.com/download.shtml . It's a PHP script package that creates those spiffy banners like you see at the bottom of a lot of posts here and on other forums.
At the link, you will see a file called wxgraphic_6.1.zip.
Inside that zip file, is a file called WeatherLink_graphictags.htx.
It's a simple text file that looks like this:
<!--stationTime-->,<!--stationDate-->,<!--outsideTemp-->,<!--outsideHeatIndex-->,<!--windChill-->,<!--outsideHumidity-->,<!--outsideDewPt-->,<!--barometer-->,<!--BarTrend-->,<!--windSpeed-->,<!--windDirection-->,<!--dailyRain-->
Those are called html tags. When properly configured, WeatherLink will read that file, recognize the tags, replace each tag with the correct current value, and the upload the file to your website. Then the fire danger script can read those values whenever the script is called, and calculate the current Chandler Burning Index/Fire Danger.
You need to save that file on your computer, and then set WeatherLink to read it and upload it. Once uploaded, you need to edit the fire danger PHP script to point to that data file to get the values.
Offline dre
« Reply #3 on: January 01, 2008, 11:02:00 PM »
Folks,
Thanks for the help.  Be sure to check out my web site and let me know what you think.
Offline dre
« Reply #4 on: January 03, 2008, 07:37:55 PM »
Folks,
Well I successfully located all the parts and the program almost works.  But I need a little more help (i think I'm overlooking something).  If I anchor the php script in the HTNL page
phic
   <a href="/fire/firedanger.php">press here for file danger</a>
it works fine, but since it is a link, you have to click on the text to make it work.
What I want to do is to have the graphic showup on the HTM page when its opened, So I put this lin in the HTML file
  <?php include("/fire/firedanger.php"); ?>
it produced no output.  Any ideas what I'm doing wrong?
Doug
« Last Edit: January 03, 2008, 07:40:02 PM by dre »
Offline Anole
    • http://pineislandweather.com
« Reply #5 on: January 03, 2008, 07:44:52 PM »
Folks,
phic
Doug
The php include should be a path not a URL. Where in relation to the html page is firedanger.php? Is it in the same directory or in a different one?
Offline dre
« Reply #6 on: January 03, 2008, 08:12:37 PM »
firedanger.php is in a sub-directory under the directory the html is in:
       |fire  --|
       |         |firedanger.php
       |         |fdl_low
       |         |fdl_high
       |index.html
this is why I have the include as /fire/firedanger.php
Doug
Offline SLOweather
« Reply #7 on: January 03, 2008, 08:51:41 PM »
I've got mine embedded in a client's index.php like this:
<p align="center"><a href="fireindexes.php"><img src="http://fire.cambriacsd.org/danger/firedanger.php"></a>
Offline dre
« Reply #8 on: January 03, 2008, 09:36:47 PM »
Yes, this code will work, but it does not give me the results I want.  I want to see the firedanger level graphic when index.html opens.
Doug
Offline Dal
  • Climbing the cliffs of Moher in my sleep
    • The Sanctuary Weather Station
« Reply #9 on: January 03, 2008, 10:46:09 PM »
Doug
Are you perhaps referring to the way I have it on www.weatherwatch.earthlights.net ? If so, try here...
http://www.southwesternweather.net/scripts.php
« Last Edit: January 03, 2008, 10:47:53 PM by Dal »
Gun tigeadh Solas nan Solas
dha m’ dhridhe doilleir o t’aite.
Gun tigeadh ais an Spioraid Air mo chridhe
Offline dre
« Reply #10 on: January 03, 2008, 10:59:41 PM »
Thanks Dal,
Took a look at your web page and figured how to make it work.  Thanks again!!!
Doug
Offline Dal
« Reply #11 on: January 03, 2008, 11:04:23 PM »
Glad I could be of help :)
